ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Engine & Transmission > Small Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old April 2nd, 2008, 02:01 PM   #1 (permalink)
The_Jeremiah
68-69 Quadrajet the same ?
Hey, I finally broke down and just bought a rebuild quadrajet from holley through schucks. I ordered one for my 69, but they gave me a 68 model. Is this model different at all from the 69 model ? if not, im not worried about it. thanks
__________________
69' Cutlass 4 door. Built 455 inside, grandma's grocery getter outside. Best sleeper in disguise.
The_Jeremiah is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old April 2nd, 2008, 05:09 PM   #2 (permalink)
The_Jeremiah
How does this look ? any info appreciated, i just want to know if this carb will be good for my engine. thanks again
__________________
Old April 2nd, 2008, 05:10 PM   #3 (permalink)
The_Jeremiah
Sorry one more lol !
__________________
Old April 2nd, 2008, 07:49 PM   #4 (permalink)
rocketraider
Oldsdruid
As long as the choke and throttle linkage hook up to what's on the car, you'll be OK.
You've got what I think is the best quality jobber reman out there. I think Holley's reman shop is a bit more conscientious about what is SUPPOSED to be in a carb than the others, who might just grab whatever's in the parts pile when they assemble it.
I've had great luck with these, in both 4GC and QuadraJet applications. One thing I've noticed is they tend to set idle mixture a bit rich on a Q-Jet. I've had to reset it on all three of their Q-Jets I've used. I mean it's rich enough to smell inside the car...
Other than that, pretty much plug and play.
__________________
I know absolutely nothing about Oldsmobiles.
Just ask the owner of Oldspower.com
rocketraider is offline   Reply With Quote
Old April 2nd, 2008, 08:06 PM   #5 (permalink)
The_Jeremiah
Ok, i figured out that the whole 68-69 thing is fine. but now what im wondering is, do i need a plate to cover the hole on the back ? im pretty sure i do, because its not plugged at all, and would cause a vaccum leak. Also the bracket for the flaps on top for the secondarys (the loop that connects to the vaccum canister) is a little tweaked i think. what do you guys think ? the piece that im talkign about, if you look in the last picture is in the top left, and is the little silver loop that connects to the long black rod that goes into the vaccum canister.
__________________
Old April 6th, 2008, 04:18 PM   #6 (permalink)
Warhead
Just make sure there is no binding of the linkage. That linkage keeps the secondary air valve closed, pretty much being pulled on all of the running time.
Do not worry about the hole.
That's a sweetheart of a carburetor!
Warhead is offline   Reply With Quote
Old April 6th, 2008, 08:06 PM   #7 (permalink)
rocketraider
Oldsdruid
The hole in the back of the carb is for a hot idle compensator. All Q-Jets have it in the float bowl casting, but it's not opened on all of them. It's for air conditioned cars.
Theory of operation: it has a bimetal spring in there that has a small cover attached. The cover fits over the hole you're worried about, and if underhood temp gets high when car is idling, that spring will snap the cover off the hole and allow extra air into the carb to lean the idle mixture out some. All this would be behind a metal plate that covers the entire rectangular opening.
__________________
Old April 7th, 2008, 12:20 PM   #8 (permalink)
The_Jeremiah
so do i need a plate ? and where do i get one if so ? thanks
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
29251 RJ '69 HO quadrajet misanthrope Parts For Sale 0 April 2nd, 2008 07:57 AM
Quadrajet identification mitsudave Other 5 November 17th, 2007 08:49 PM
1970 -72 quadrajet agtw31 Parts Wanted 0 March 15th, 2007 02:49 PM
quadrajet 7040253 need chevelle_ss 442 7 February 2nd, 2007 06:51 AM
Quadrajet Thomas Simcich Parts Wanted 0 October 30th, 2005 07:11 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
