Starting issue
Starting issue
OK today I fixed a bent fuel elbow, put in a shinny new vacuum advance, and changed the oil.
I put in the fuel elbow on vacuum can before I even started the car. Car started up fine.
Took it for a drive to see if the advance is working or if the timing is off, seems to be a little bit better, but I think the timing is up too high.
Pulled up in front of my house, doubleparked, pulled the wifes car out of the way and parked my car there and got it up on the stands. Changed the oil (I used all 10w-30 conventional, 3 quarts of Shell, and 2 quarts of Quaker State) and after I was done I started the car and the crank was weak, very weak like it wasn't going to start. It did start though. The water temp was at 170* or so
I just took it out for a spin. The engine had very little warmth on the manifold, and the water temp gauge was resting on the bottom peg. It did give that "crank-nothing-crank-nothing-crank-start" but it started up. I put it sideways a bit pulling out of my delevopment and it moved when floored.
Drove around for a few mintues, got home and the temp was at 180*. waited a mintue with the motor off, but the key on and the electric fan kicked on (195* on) the car did start, but it was like "errr--------------------errr-----------------errr---------start *weak like less than 500 rpms and then ran fine. Turned it off and tried again and it cranked weakly, but WOULD not turn over.
After reading many posts on here, I'm pretty sure it's the timing. Am I right? hopefully I am, because if I am, the advance is working and retiming it is no problem
The timing was set to 34* total, but if the advance wasn't working then, that means it was at 34* instead of 20* The only thing is that I wasn't getting any pinging and the car ran great
From: https://classicoldsmobile.com/forums...html#post15640
Check your starter/battery/charging system.
Norm
When you changed the vacuum advance you altered the initial timing. Set the timing with a timing light & the vacuum advance disconnected.
If your "Hot Start" problem persist you would then need to "Check your starter/battery/charging system."
Don
Don
Read post #4 again.
"Not working" is the same as, disconnected.
There is no evidence that points to a "hot start" problem, whatever that might be.
Norm
Did you forget to tighten your distributor after you set the advance? If so, you could have moved it during the R & R. But:
From post #4:
Norm
Norm
Not possible. The only way the initial setting can be changed, is by rotating the distributor.
Read post #4 again.
Read post #4 again.
Yep, sounds like you initial timing is off, too advanced I believe,
Can't remember if Redog's problem is too advanced or too retarded. But if the initial timing is retarded it would explain the lack of "pinging".
Redog, set your timing, charge your battery and see if the problem is still there. (When the engine warms up)
Don
........ got it up on the stands. Changed the oil (I used all 10w-30 conventional, 3 quarts of Shell, and 2 quarts of Quaker State) and after I was done I started the car and the crank was weak, very weak like it wasn't going to start. It did start though. The water temp was at 170* or so ........
Norm
The car had a weak crank, but I remembered while talking to my buddy about it, I left the door open a crack during the oil change. That was Sunday, I started it last night when I came home from work (12:30 Tuesday) good crank and fired right up, but I turned it off because I wasn't go to try anything at that time.
Got an inch of snow today and freezing rain now, going to rain all day tomorrow, so I'll play right the timing later
1970cutlasssupreme
Oct 4, 2013 10:29 AM
