intake manifold vacuum ports
Old September 3rd, 2012, 03:14 PM
rmoths's Avatar
Wink intake manifold vacuum ports
I have a Street Dominator intake manifold on my 350 motor.
There is a small vacuum port behind the carb. Well strange as it seem the motor semms to run a little better with the vacuum port open.
Should all vacuum ports if not used be pluged or can they be left open.
Seems to me you would loose some vacuum with it open, but the car at least idles better with the port open. Barb.
rmoths is offline
Old September 3rd, 2012, 04:10 PM
Sorry Barb, those ports need to be plugged. It seems to run better, but believe me it does not.
oldcutlass is online now
Old September 3rd, 2012, 04:24 PM
ah64pilot's Avatar
Eric, if it idles better with it open would that indicate the carb is too small? Or maybe not too small, but that it would benefit from a larger one? IDK...just wondering myself
ah64pilot is offline
Old September 3rd, 2012, 04:27 PM
Tony72Cutlass'S''s Avatar
When my timing chain skipped 30 degrees, my 350 block ran smoother when the #8 spark plug was unplugged.
THAT was weird..
Tony72Cutlass'S' is offline
Old September 3rd, 2012, 04:40 PM
I would say it indicates her tune may be a little off. It's probably adjusted to compensate for the vacuum leak.
Tom442
June 9th, 2014 04:54 PM
KQQLCAT
January 11th, 2011 09:43 AM
rcdynamic88
October 19th, 2010 06:05 AM
DAN76
June 24th, 2009 01:43 AM
blonzz
September 27th, 2004 10:54 AM
Quick Reply: intake manifold vacuum ports
