Exhaust, The Final Tech Question
Old Dec 16, 2007 | 06:23 PM
SPEEDROCKET's Avatar
Would a 3" exhaust with the set up on my other post work well with what I'm doing? I want to run the 3" exhaust that will have a X-pipe with super 40's or super 44's depending on my mood when I order them. This question is strickly for the purpose of performance. I know it should sound good.
Old Dec 16, 2007 | 06:52 PM
kevinkpk's Avatar
Larger exhaust will not increase horsepower, but will allow what you have under the hood to be more "useful", in other words you won't loose as much horsepower with a lower back pressure. Routing exhaust pipe is a pain, and rather dual, versus single with a larger diameter might be the way to go.
Old Dec 16, 2007 | 07:59 PM
So, it's safe to say I won't "lose" any horsepower either? That's the only thing I'm worried about. I plan to run dual exhaust with the x-pipe, as far as routing goes, that's what the exhuast shop is for!!!! I had dual 3" on my 82 cutlass and I wouldn't of done it myself for anything.
Old Dec 16, 2007 | 08:08 PM
kevinkpk's Avatar
Horsepower loss is due to exhaust piping, you want to run (ex) open exhaust headers, you will realize almost zero horsepower loss.
Old Dec 16, 2007 | 08:29 PM
What do you think if I were to bring the exhaust out in front the the rear tire? Think this would eliminate flow problems of going over the axle?
Old Dec 16, 2007 | 08:48 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Take a crayon and draw a thick line down your exhaust until about the middle of the car.
Then start it up and go race a 1/4 mile.
Where ever the crayon is still left unmelted, is where it's safe to dump your exhaust off at.
My opinion only, though.
I believe having an X pipe and full exhaust is worth more horsepower than straight dual exhaust, however.
Old Dec 16, 2007 | 08:54 PM
Oh yea, I'm all about the X-pipe.
Old Dec 16, 2007 | 09:59 PM
Redog's Avatar
That's the set-up I have on my Delta, only I have 2.5" x pipe with Super 40's
Sounds good, works good.
Old Dec 17, 2007 | 04:29 AM
So you think a complete 2.5 will be totally adequate with out losing any power on this application then? If so I'll go with that. I just need to come up with something before I order the mufflers so that i get the right size.
Old Dec 17, 2007 | 12:17 PM
Redog's Avatar
X pipe equalizes the exhaust flow, so if you are going to have 400+ hp, 3 inch is fine
Old Dec 17, 2007 | 07:01 PM
I'm hoping for about that much!!! Thats what's prompting this inquiry!!
TerryZekeMaxwell
Nov 16, 2011 05:46 AM
70Post
Jul 26, 2011 04:38 PM
jensenracing77
Dec 6, 2009 01:24 PM
SPEEDROCKET
Dec 18, 2007 06:35 PM
