Red line on a 68 350
Old Nov 15, 2007 | 10:43 AM
Redog's Avatar
Question Red line on a 68 350
Like the title says:
What is the red line on the 350 395558 block?
I don't go above 5k, but I may have the car on a dyno tomorrow and I want to know what the red line is.
I've heard 5500. I want to keep it under 5200 at the most. It only gets to 4600 in the 1/4 mile
Old Nov 15, 2007 | 12:48 PM
captjim's Avatar
It should go to 5500 safely, but it will be done making power long before that, so why do it?
Old Nov 15, 2007 | 12:57 PM
Redog's Avatar
It doesn't have a rev limiter so I want to stop it before that point
Old Nov 15, 2007 | 02:55 PM
captjim's Avatar
Does it have a tach and/or a shift light?
Old Nov 15, 2007 | 08:04 PM
88 coupe's Avatar
Junior Member
Originally Posted by Redog
........ What is the red line on the 350 395558 block? ........
The "old school" definition of "red line", is your "shift point". There are some variables but, for you, the RPM at the peak HP reading, minus 500 for the 1-2 and plus 200, for the 2-3 shift, might be a good starting point.
Since you asked about a specific "Block" We could assume you mean its breaking point. Simply put: At your power level, you cannot rev it high enough to break it.
If you are looking for a more specific answer, you will need to clarify your question.
For a dyno pull?
Norm
Old Nov 16, 2007 | 09:30 AM
Redog's Avatar
Yeah I have a tach in the car.
Plus I was looking at a Mallory dist. and it has a rev limiter. I'd probably set it at 5200
Old Nov 16, 2007 | 12:45 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
11TH COMMANDMENT:
Thou shalt not overrev thy rocket.
Old Nov 16, 2007 | 12:48 PM
Redog's Avatar
^ Becuase Thy don't have the money for a rebuild
vette442
Jan 6, 2015 07:54 AM
1969 442 w30
Jan 1, 2012 11:15 AM
1969 442 w30
Oct 8, 2011 04:57 PM
Flye
Jul 31, 2009 04:03 PM
68conv455
May 20, 2008 02:03 PM
