'69 350 oil filler tube removal
Old Sep 3, 2007 | 03:28 PM
blunce's Avatar
This is the last part still attached to the block I am prepping for rebuild. I can't figure out how to get the oil filler tube out without marring the surface with say channel locks.
Old Sep 3, 2007 | 05:35 PM
millwrightrice
Guest
Posts: n/a
Try a strap wrench and a teflon hammer to jar it loose.I guess its going to machine shop.
Its really a pain in the ***.If for ANY reason it can be left than do so.
Old Sep 4, 2007 | 07:01 AM
This is unfortunately a big problem. I usually tap the tube back and forth with a rubber mallet to loosen it. It's a time consuming process. Usually I give up and end up marring the tube with pliers...
Old Sep 4, 2007 | 09:39 PM
blunce's Avatar
This worked except it came out before I got to the giving up part. Knocked it back and forth several times then started hitting upward on the point of the tube near the bottom that goes from large to small. Also soaked the area with wd-40 several times since yesterday. That probably helped too. Thanks for the tip Joe!
Old Jul 21, 2014 | 03:59 PM
hackmansr's Avatar
Speaking of the oil filler tube on a 1969 350, what color did the factory paint the tube, black (gloss?) or gold?
Old Jul 21, 2014 | 05:43 PM
Paladin31's Avatar
Find or fabricate a wooden dowel or old hammer handle ...etc... that can be made to just fit inside the filler tube & then 'worry it' back and forth gently and it will walk back out of the hole relatively easily. Not fast but will keep the tube and more importantly the cap seat intact. Learned this after destroying my first one, and an older & wiser suggestion was offered, Good luck
Brett
Old Jul 21, 2014 | 06:43 PM
1. This thread is from 2007.
2. The factory painted the whole engine gold, including the oil fill tube.
Old Jul 23, 2014 | 04:47 PM
hackmansr's Avatar
Thanks Eric. I did notice it was an old thread.
Old Jul 23, 2014 | 07:19 PM
Just throwing it out there early. Sometimes one guy will post on an ancient thread, then another ten will pile on with advice for the OP, who's probably gotten divorced, sold the car, bought a Vette, met some young chick, and is remarried already.
Old Jul 23, 2014 | 07:41 PM
Octania's Avatar
Ah, but new folks also need this tube removal advice.
When I first joined, I was replying to ages-old threads because they were presented to me, and the last addition date was not easy to spot.
I too got schooled and chastised. Now I only do FRESH threads!
Theo's '67
Jun 7, 2011 11:43 AM
yopester
Nov 18, 2010 09:46 PM
ctrain22
Jul 29, 2009 10:46 AM
68Tom
May 24, 2009 12:53 AM
54olds
Sep 4, 2008 07:15 PM
