Cutlass Supreme headers?
Old Jul 31, 2007 | 07:03 PM
GoldOlds's Avatar
Unhappy Cutlass Supreme headers?
What do header companies like Hooker and Heddman have against the Cutlass Supreme? EVERY single SBO header they make appears to have a "Will not fit Cutlass Supreme" footnote on it. What's so different between the CS and the "regular" or even 442 Cutlass? Does ANYONE make a header to fit my '69 Cutlass Supreme (350)? Specifically, one with 2.25" collectors or 2.5" collectors with available 2.25" reducers? The cam upgrade I want to do will be mild, but not so mild that it won't need headers.
Thanks!
- GoldOlds
Old Jul 31, 2007 | 07:07 PM
texasred's Avatar
Tom Servo's Stunt Double
Just order a set for a Cutlass 'S'. There is no mysterious "engine offset".
C.J.
Old Jul 31, 2007 | 07:45 PM
Absolutely NOTHING. At least through 1972, the Supreme and Cutlass use exactly the same frame, motor mounts, block, trans mount, etc, etc. The manifolds and exhaust pipes are the same. The sheet metal and inner fenders forward of the firewall are the same. Prior to 1970, even the BODIES were the same (the notchback Supreme didn't come out until 1970). I have personally contacted Hooker Headers about this and got a polite form letter that basically said "thanks but no thanks".
This comes up at least once a month. It's an urban myth. Just order headers for a Cutlass.
Old Aug 1, 2007 | 08:36 AM
Jokers69's Avatar
Senior Moment
I have a 69 Supreme with a 350, my cheap a$$ Flowtech's I bought from JC Whitney work just fine. I had to remove the starter and oil filter bracket, drink a few beers and cuss a bit, but they went in.
Old Aug 3, 2007 | 08:13 PM
GoldOlds's Avatar
Thanks, guys, I'll ignore the footnote. I THOUGHT it sounded odd that any given headers would fit a plain Cutlass or 442 but not a CS.
- GoldOlds
Old Aug 22, 2007 | 08:06 AM
millwrightrice
Guest
Posts: n/a
Beer and cussing helps me out alot.At least Olds headers lay under the plugs and are really simple compared to shitrolet's.
Old Nov 26, 2011 | 09:00 AM
70ConvCutlass's Avatar
Anyone have any magic tricks for installing heddman headers? The machine shop had them installed for the engine break-in, but mechanics can not get the right side to reinstall now that the engine is back in the car. This is a 70 Cutlass Supreme w/ original 350. Summit Racing and Heddman claims these headers are specifically made for this combo. I'm thinking there must be a trick to the install process??
Old Nov 26, 2011 | 11:08 AM
bigD's Avatar
are they trying to come up from the bottom or down from the top? A/C car? to me the right side was always the easy side...
Old Nov 26, 2011 | 12:45 PM
don71's Avatar
same but different
Yea, the right side has allways been the easy side for me too.
Remove the oil filter and the housing it attaches too. Re-install after the header is in.
Old Nov 26, 2011 | 01:08 PM
Thanks guys. I had already told him he needed to remove the oil adaptor and filter, but he was still having a problem with it. I waiting to hear back from him this afternoon.
Old Dec 1, 2011 | 04:44 AM
507OLDS's Avatar
The passenger side is easier to install by going up from the botttom,and yes,that is the simple side.
Old Dec 19, 2011 | 10:52 AM
69oldsdude's Avatar
i have two sets of headers im selling that i pulled my 1969 cutlass 442 ill take 50 bucks for them!!! 2107331967
Old Dec 19, 2011 | 10:54 AM
69oldsdude's Avatar
50 bucks a set my names tony and im in san antonio tx
Old Dec 19, 2011 | 12:50 PM
Final got the headers/engine install compete. Next step is dual exhaust. I think we're going to go with Magnaflows..
Old Dec 19, 2011 | 06:43 PM
jimmyp618's Avatar
Ill take a set of em if theyll fit a 68 350 cutlass. Shipping will be to godfrey Illinois 62035 . Thanks Jimmy
Wyze
Mar 18, 2012 01:59 PM
TOONLOVESCHERYL
Apr 7, 2011 10:38 AM
import extermination
Sep 9, 2009 11:02 PM
dhoff
Jan 4, 2009 01:46 AM
bigcaser
Jul 22, 2004 12:28 PM
