Head Numbers
Check this out http://s122.photobucket.com/albums/o...nt=Head_ID.jpg and then check the Performance and Tech articles on the first page of this site and that'll pretty much tell the story.
C.J.
C.J.
Look on the front side corner of your driver's side cylinder head, close to the front spark plug. If your '67 330 has the original heads, there should be a #4 on them. That'll mean you have 60cc combustion chambers (high compression?), although I don't know what your valve sizes would be. 394497 should be the number you see when you remove the valve covers. Click on "Oldsmobile Performance" on the front page of this site, as Texasred suggested. Lots of good info there. I THINK all 330s had steel cranks, but I'm not 100% sure - I'm still learning!
- GoldOlds
- GoldOlds
