Intake manifold
Old May 31st, 2011, 07:37 AM
66olds4dr's Avatar
Intake manifold
Hello
1966 Olds 330.
Would like know if there is a difference between california emission Manifold and Non california Manifold?
66olds4dr is offline
Old May 31st, 2011, 08:16 AM
Originally Posted by 66olds4dr
Hello
1966 Olds 330.
If your question is about the intake manifold, the answer is no. In 1966, the main difference between Calif cars and 49 state cars is the A.I.R. system (aka, the smog pump). A.I.R. used injector pipes that attached to tapped holes in the heads. There were a couple of vacuum connections to the intake as part of this system, but the threaded holes for those were on all 1966 intakes. They were simply plugged if not used.
joe_padavano is offline
Old June 2nd, 2011, 03:39 PM
66olds4dr's Avatar
Thanks you
shamusj
December 18th, 2014 09:28 AM
svnt442
July 17th, 2011 04:43 PM
jjatich
July 29th, 2007 07:57 PM
SMOKEYMTNKUSTOMS
October 12th, 2006 12:18 PM
magnusdog
September 2nd, 2006 10:01 PM
Quick Reply: Intake manifold
