330 #2 heads on 75 350
Old Jul 27, 2009 | 05:16 AM
65cutty's Avatar
would 330 #2 heads be ok on a 1975 350 engine? going to have harden valve seats put in and leave all the rest stock, going to use stock head gaskets. what do you think...jim
Old Jul 27, 2009 | 07:20 AM
The only things to be aware of are 1) actual compression ration (though you should be fine, particularly if you are using the Felpro blue gaskets) and 2) the pushrod holes, which may need to be enlarged for clearance due to the 45 deg vs. 39 deg lifter angle.
Old Jul 27, 2009 | 08:57 AM
64Rocket's Avatar
Didn't the later 350 engines use the bigger head bolts?
Gene
Old Jul 27, 2009 | 10:09 AM
Gene
1977-up used the 1/2" head bolts (to make up for the windowed, thin wall blocks). The 1975 motor in question should have the same 7/16" bolts as the 330. Of course, the early heads can be drilled out in any case.
Nor Cal Andy
Aug 22, 2011 07:17 PM
acre03
Mar 29, 2009 03:11 PM
65cutty
Oct 30, 2008 08:27 AM
65cutty
Aug 27, 2008 10:09 AM
Run to Rund
Aug 4, 2008 02:08 PM
