330 Fuel pump... Same as a 350/400/455?
Old Jun 18, 2009 | 10:11 AM
RAMBOW's Avatar
Ben
Question 330 Fuel pump... Same as a 350/400/455?
Is a 330 fuel pump the same as a 350/400/455?
Napa & Schucks both don't list one for the 330. Summit has a Mr Gasket one, but i don'treally want to pay $12 shipping...
Hopeing one of the others is the same and the catalogs are just messed up.
Thanks.
Ben
Old Jun 18, 2009 | 10:54 AM
Thanks.
Ben
They may not be identical, but they are interchangeable. The only meaningful difference is whether the pump has the third connection for the return line or not. As a rule, hi-perf and A/C cars used fuel return, lesser cars did not.
Old Jun 18, 2009 | 11:02 AM
RAMBOW's Avatar
Ben
Cool, thats what i was hoping, and what i needed to know.
Mine only has the single line, So hopefully one for 350 would have a single line too...
THanks!
Ben
Old Jun 19, 2009 | 07:02 AM
RAMBOW's Avatar
Ben
Hi Joe-
Doing a little more research... Fusic's catalog does not list a pump for 1966 330. 64,65,67- but no 66.
For kicks i went back to www.napaonline.com and searched for a 67 cutlass 330- and it lists a pump... 65 lists two different pumps- and 64 lists a different pump still.
are these differences in the way the fittings are clocked, or something else?
I'm worried ordering the 67 pump, that maybe something with the 39 vs 45 degree cam bank might cause issues (didn't 67 330's change the cam bank angle?)
Thanks...
Old Jun 19, 2009 | 02:49 PM
svnt442's Avatar
Cam bank angle won't have anything to do with the fuel pump. Just the return line hook up and possibly the height of it. I think (I could be going senile) have seen some tall ones, but I think those are only for the BB.
Old Jun 19, 2009 | 06:56 PM
I've never paid much attention to exact catalog listings for fuel pumps and I've never had a problem bolting any Olds fuel pump to any Olds block. You can even cap the return fitting on the pump if you don't need it. There may be some differences in clocking of the inlet and outlet fittings, but nothing that rebending the line won't fix.
Old Jun 19, 2009 | 10:08 PM
RAMBOW's Avatar
Ben
ok, cool.
I ordered one from napa for a 67 330. $33, so i can't complain.
New gas tank will be here next tuesday as well. Hopefully between these two it will solve my gunk in the carb problems.
Old Mar 30, 2010 | 07:03 AM
scubastever's Avatar
this is not my car lol
http://www.oreillyauto.com/site/c/se...***&vi=1346273
cheaper at Murrays!
Old Apr 1, 2010 | 06:39 PM
nebuckeye's Avatar
I have a 66 330 no ac, I got my pump at napa, it bolted right up and works fine
RAMBOW
Jul 29, 2013 05:32 PM
62radarlove
Mar 7, 2012 09:23 AM
beerdeadladies
Sep 4, 2010 07:21 PM
ctrain22
Jul 10, 2009 08:13 AM
jeffreyalman
Jun 6, 2009 06:28 PM
