felpro head gaskets
Old May 26, 2009 | 01:27 PM
65cutty's Avatar
felpro head gaskets
when using these do you want to copper coat them?
Old May 26, 2009 | 02:34 PM
OLDSRALLYE350's Avatar
Felpro blue headgaskets are ready to use from the box no sealer needed.
Old May 26, 2009 | 06:05 PM
64Rocket's Avatar
Copper coat is not a bad idea. I do it to help seal better. It's up to you, what ever you feel like.
I spray them and let dry for a couple of hours.
Gene
Old May 26, 2009 | 07:34 PM
442scotty's Avatar
Felpro does not need it...I would think if you do spray you better get it on even...a few thou off and here and there could cause problems...
Also...just wondering...wouldnt spraying the head gasket interfere with the thickness and cause problems with the sealing rings?
Old May 27, 2009 | 07:06 AM
Copper coat is for steel shim head gaskets. The FelPro blue gaskets do not need nor want any coating.
Old May 27, 2009 | 07:15 AM
65cutty's Avatar
thanks for the great info and this keeps folks from making the mistakes,....jim
Old May 27, 2009 | 09:32 PM
geckonz08's Avatar
Only some folk Jim --but yes I do make less mistakes than otherwise
mike
coppercutlass
Dec 24, 2013 08:03 AM
69442C
May 21, 2011 06:28 AM
Wasted
May 1, 2010 07:00 PM
smcurro
Feb 11, 2009 08:47 PM
Deltarocket
Jun 5, 2007 06:54 AM
