Engine Identification
Old Mar 19, 2009 | 07:22 PM
65az's Avatar
So how do I figure out what engine I have...
403 CI.
Valve covers 350 hp, 400lb ft of torque
Left head says 4A 554 717 stamped on it
Block on the front top says 557265
Old Mar 19, 2009 | 11:22 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
http://oldsmobilewiki.com/index.php/...Identification
It's a small block Oldsmobile 403.
Roughly 170 horsepower in stock form.
Old Mar 20, 2009 | 06:20 AM
Um, you mean besides this:
403 CI.
Are you talking about a decal that looks like this:
If so, that decal was used on the 1967 E-block 400 motor. It was never used on the 403. Someone just put it there.
Old Mar 20, 2009 | 07:33 AM
65az's Avatar
I guess I wasnt clear, I am looking for the year of the motor, and is it a good strong motor? Are the heads any good? If the decals are not right, is it really a 403?
Old Mar 20, 2009 | 08:07 AM
None of those decals were original to that motor, nor was the air cleaner. The block and head casting number do indicate that it's a 77-79 403 motor. Can't tell about the rest of it, since it's clearly been messed with by a previous owner.
Old Mar 20, 2009 | 09:36 AM
65az's Avatar
Well I knew the decals were not correct.. at least some of them. Is this a good strong motor? I did see the build sheet on it, it is running a mild cam, and supposedly dyno'd at 350HP.
Old Mar 20, 2009 | 11:25 AM
In stock form the 403 put out nowhere near 350 HP. The 403 has siamesed cylinders, unlike any other small block Olds. That level of power would require a cam, some head work, and intake and exhaust. That single plane Offy 360 intake is not one of the better aftermarket units around.
vinnie
May 13, 2007 02:49 PM
LundyT
Sep 4, 2006 06:46 AM
tristansdaz
May 1, 2006 06:54 AM
lambinowelding
Oct 21, 2005 04:12 AM
airjester2000
Jul 31, 2004 12:45 PM
