What does the number on the starter block mean?
Old December 17th, 2014, 06:05 PM
The Stickman's Avatar
I am in the process of doing a starter swap and I noticed a number on the mounting block for the starter. Pretty sure it was 5521 but will have to check again. Just wondering what it means. For some reason this engine is giving me fits getting a starter mounted, The adjustment is way off no matter what starter I try. I end up having to take material out of the starter mount just to get the gear close.
The Stickman is offline
Old December 17th, 2014, 06:42 PM
Octania's Avatar
Oh yeah, the 5521 blocks require a special 5.5 HP 220V 1-phase starter.
But, seriously, no one knows what that number is for. Large characters, lightly and perfectly stamped. I suspect it was the line number of the blocks as they were machined, so that in case of issues, a range of numbers could be quarantined or whatnot. I have never seen it mentioned or used in normal practice. Julian date of the machining perhaps? If so then a block machined 01Jan1968 would be stamped 0018 or 8001
are you sure you don't have a rare Toronado of certain year smaller diameter flexplate? I have NEVER had ANY shimming necessary on an Olds starter. Factory or aftermarket starter?
Octania is offline
Old December 17th, 2014, 07:01 PM
The engine and flexplate are out of a Chevy pickup. I bought the truck for the engine. It must have had a diesel in it and had it changed over to gas. Not sure what the engine came out of or what parts they used to make the swap.
Old December 17th, 2014, 08:09 PM
Hangin' out...
henryk8398's Avatar
What kind of starter are you installing? The 350 diesels in cars and trucks are different, so I'm wondering if you might need to install a starter from a 350 diesel passenger car.
henryk8398 is offline
Old December 18th, 2014, 05:29 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
The 350 diesel starter is much larger than the regular Olds 350 starter, that would cause your issue.
olds 307 and 403 is offline
Old December 18th, 2014, 06:02 AM
'87 Delta 88 Royale
rustyroger's Avatar
They are?. What are the differences?.
Oh hang on, do you mean the diesel starters are different to gasoline engine starters?. I would get a gasoline flexplate in that case.
Roger
rustyroger is offline
Old December 18th, 2014, 07:21 AM
i found this on my 72 when I rebuilt my starter 2 years ago. I also,wondered what it meant.
Allan R is offline
Old December 18th, 2014, 07:22 AM
stellar's Avatar
Wouldn't putting a diesel starter in be easier?
stellar is online now
Old December 18th, 2014, 09:36 AM
Octania's Avatar
Now we need a starter/ flexplate study with photos and numbers...
NOT ME
Octania is offline
Old December 18th, 2014, 12:33 PM
Found the pic I was looking for earlier. Here's the stamping from the block under my starter.
My starter had no shims when removed, and went back in the same way without any issues.
I'm leaning toward this being a production date code. My car was built at Lansing in April which is the 4th month and completed on the 11th day. That would be close to the same time the engine would have been produced so I think the 407 relates to production date. I'm thinking that 5 was the "Lansing" Motor division that built it. Any thoughts?
Allan R is offline
Old December 19th, 2014, 07:43 AM
80 Rocket's Avatar
NOT ME
I nominate Octainia......oh, nevermind
80 Rocket is offline
Old December 19th, 2014, 02:07 PM
Lars's Avatar
Lol there's a starter and flex plate parts advertisement on the bottom of the page
Lars is offline
Old December 19th, 2014, 03:07 PM
Octania's Avatar
I see "6407" there... rules out the YJJJ or JJJY code where Y is Year final digit, and JJJ is three digits for Julian Day of the Year.
Octania is offline
Old December 19th, 2014, 04:33 PM
Nope - it's 5407. The camera flash just makes it look like a 6. The 5 is not stamped very well at the top, but I know for a fact it is a 5. The bottom part of the 5 is not closed loop as a 6 would be.
Allan R is offline
Old December 19th, 2014, 05:15 PM
Octania's Avatar
Here are a few others
[IMG]
7198_74-455_P11BLOCK_CN6aStarterBoss3316_zps919e9bac.jpg[/IMG]
Octania is offline
Old December 19th, 2014, 08:33 PM
BTW the new high torque mini starter is in after taking quite a bit out of the mounting plate. The last starter was dieing because of heat issues. Would work fine when cold but have big troubles when hot. This should solve the problem.
Adam67
May 9th, 2015 04:50 PM
tj78_
October 21st, 2010 06:03 PM
cogaritis
August 7th, 2009 01:43 PM
snowballs442
August 1st, 2009 05:41 PM
GoldOlds
May 22nd, 2007 09:19 AM
Quick Reply: What does the number on the starter block mean?
