Two Barrel/Four Barrel Intake
Old January 23rd, 2017, 08:46 AM
VI Cutty's Avatar
Is the stock intake manifold for a 1971/2 350 the same for two and four barrel carbs, or different manifolds for the application?
Going to be swapping a 350 with a two barrel into my new '70 and will be rebuilding a QJet for it later this year.
VI Cutty is online now
Old January 23rd, 2017, 08:51 AM
classicmuscle442's Avatar
The intake are the same, only difference is between small and big block Olds because of deck height.
classicmuscle442 is offline
Old January 23rd, 2017, 09:01 AM
VI Cutty's Avatar
That makes life easier, thanks!
Old January 23rd, 2017, 09:38 AM
Um, what do you think?
joe_padavano is offline
Old January 23rd, 2017, 09:47 AM
oldsmobiledave's Avatar
what?
What does deck height have to do with carburation? He asked if 2 & 4bbl are the same not if SBO & BBO are the same. I don't understand your answer.
oldsmobiledave is offline
Old January 23rd, 2017, 09:54 AM
In fairness, given the obvious answer to the original question, I think his eyes saw one thing and his brain read something else. I'd be lying if I said I'd never done that.
Old January 23rd, 2017, 10:30 AM
VI Cutty's Avatar
A picture's worth a thousand words; thanks for the clarity, Joe.
Old January 23rd, 2017, 12:56 PM
woops, meant block deck height difference from small and big block not carb opening. On pain pills from shoulder surgery. nap time
Old January 23rd, 2017, 03:48 PM
Hookers under Hood
76olds's Avatar
Its ok, our members understand mistakes happen, especially when pain takes over the mind.
We have great members here that post corrections without bashing the poster that makes the error.
Cheers, have a good nap,
Eric
76olds is offline
Old January 24th, 2017, 03:20 PM
BlackGold's Avatar
I see your point, Joe. The 2 bbl manifold has the thermostat housing on the right, while the 4-bbl has it on the left. Clear as day.
BlackGold is offline
Old January 25th, 2017, 05:59 AM
I'm glad SOMEBODY'S paying attention.
Old January 25th, 2017, 12:28 PM
VI Cutty's Avatar
Well I'm screwed then. Both my intakes have the housing on the right.
AND I misplaced my left handed screwdriver.
Old January 25th, 2017, 12:44 PM
Thought I had one I could lend you, but I checked, and it's metric.
MDchanic is offline
Old January 25th, 2017, 07:36 PM
Metric
That's fine. We use the metric system here in Canada.
Beau Dirt
December 27th, 2021 03:02 PM
RetroRanger
November 21st, 2016 10:11 AM
edzolz
October 10th, 2014 08:55 PM
442much
October 30th, 2010 08:48 PM
Quick Reply: Two Barrel/Four Barrel Intake
