NASCAR blocks
NASCAR blocks
I need to ask,... what's the difference between a Nascar Olds block and a regular Olds run of the mill block?
455? 350? What blocks were available at what CID.
Eric
Eric
The NASCAR block was a factory race part cast in the mid-70s when Olds actually ran Oldsmobile motors in Cutlass stock cars. AJ Foyt was one driver who ran these. The block was much beefier than stock and had four bolt mains (as shown below). Typically run with Batten heads.
Just talking out loud here,
I thought I heard here that the Nascar block had a higher nickle content. For those here that know cast and steels!!
If someone were to take a block of P-20 material which is between 38-45 rock well, tried to duplicate a 350 block with 4 bolt mains for kicks, would the P-20 be somewhat close to the casting of the Nascar block?
Eric
Eric
Eric
Eric
Very interesting subject. Was the last Oldsmobile engine used when the '76 & '77 Cutlass bodies was no longer allowed for NASCAR racing?
I cannot recall the maximum engine size for NASCAR after the 426/427/428 engines were banned, only that the aero cars were limited to around 350 cubic inches after the 1970 season.
Does anyone remember the driver who raced a '70 Cutlass in NASCAR. I saw his name and the car mentioned in an old Motor Trend magazine in the race results section, but now cannot find it.
Were Chevy engines exclusively used in every NASCAR '81-'88 Cutlass, or did any of the teams use an Oldsmobile engine?
Thanks for posting the web thickness differences Joe. Due to the small web casting in the street production blocks were their many other differences that you know about ?
Eric
Eric
