71 choke tubes
Old February 13th, 2006, 10:05 AM
Poetry Rod's Avatar
71 choke tubes
I am trying to locate were the choke tubes coming out of the intake pipe to. I do have the first tube closest to the front hooked up, it screwed into the choke housing, but the second tube comes up and hooks to a vacum line to somewere. Thats the one I'm trying to locate the piping point to.
Thanks,
Doc
Poetry Rod is offline
Old February 22nd, 2006, 08:05 AM
jdorour's Avatar
Starting at the choke spring housing the tube goes into the tube at the exhaust crossover in the intake manifold the other side comes out of the tube in the exhaust crossover up to the top of the carburator air horn.
Airflow goes from the carb airhorn (top of the carb) thru the heat stove (u shaped tube in the exhaust crossover in the intake manifold) to the choke spring housing ( heating the spring to open the choke) thru a hole in the choke housing and into the carb.
jdorour is offline
WTony
December 3rd, 2014 04:16 PM
WTony
September 12th, 2014 06:10 PM
MHENDERSON
June 14th, 2013 03:29 PM
Nasty455
May 29th, 2012 05:05 AM
Poetry Rod
February 18th, 2006 09:51 AM
Quick Reply: 71 choke tubes
