#6 heads with 2.00 intake
Old March 3rd, 2014, 05:39 AM
Babafats's Avatar
I just had my heads pulled off by a resto shop locally to have some valves checked out and the mechanic working on the car showed me and told me that the intake valves were 2.00 is this different than the normal intake valves on a 1970 350 cutlass or is it the same because the intake valves im seeing as replacements are smaller.
Any ideas would be great thanks guys.
(had a low popping noise coming out the exhaust sounded like one valve was acting up, timing and carb are down pact)
Babafats is offline
Old March 3rd, 2014, 08:20 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Olds used the 2" valve in the W31 350, regular 350 is 1.875", someone probably added bigger valves.
olds 307 and 403 is offline
Old March 3rd, 2014, 10:47 AM
oldsmobiledave's Avatar
or
Or they are original W-31 heads that migrated to this engine.
oldsmobiledave is offline
Old March 3rd, 2014, 11:27 AM
Chevy budget Olds powered
coppercutlass's Avatar
Maybe its w31 engine. Does it have flat top pistons or the big balancer or aluminum intake ? Just a though. Some of those parts would bring in enough money to build you a very nice stout engine.
coppercutlass is offline
Old March 3rd, 2014, 06:23 PM
Babafats's Avatar
flat top pistons but the intake is not orginal
Babafats is offline
Old March 3rd, 2014, 06:28 PM
Might be worth looking into the code of the engine. You never know.
Old March 3rd, 2014, 06:36 PM
Babafats's Avatar
how could i look into more detail what the car is? im doing the vin now, for example the previous owner labeled at as a cutlass sx, but its a Cutlass Supreme, so i was never actually told what it was for sure
Babafats is offline
Old March 3rd, 2014, 06:38 PM
Babafats's Avatar
how would that help me into building a "stout" engine, i would want to keep it even if it isnt w-31
Babafats is offline
Old March 3rd, 2014, 06:44 PM
This is all thinking out there. Maybe down the road someone stuck a w31 engine in there without knowing . It's a possibility lots of these cars ended up in junkyards . It would help you build a stout engine if there where real w31 heads or if it had a w31 intake or balancer because those a big buck items hard to come by that purist would buy if they where the real deal parts. This is where digging into what it is would help. To find out what the engine is you gotta look at the pad under the cylinder head on the front of the engine on the dr. Side.
64 CUTLASS KEN
December 7th, 2020 06:43 AM
olds4life
December 25th, 2012 12:56 AM
svnt442
July 17th, 2011 04:43 PM
gearheads78
November 10th, 2009 09:31 PM
DarkStar
October 21st, 2009 07:35 AM
Quick Reply: #6 heads with 2.00 intake
