Valve and spring recommendations???
I've asked this question befor but I figured I would get better answers if I made it separate thread for it. I'm using stock 350 heads. Been ported and gasket matched. No other work was done to it. What size valves should I use and what other kind of work( if necessary ) should I have done to my heads. Thanks
I think Your machine shop should be able to set you up. No offense but if they are already working on your heads aren't they planning on doing a valve job ? Usually its all done at the same time usually the shop will ask what your plans are what you want to run. Usually big intake and ex. valves better springs and all new hardware are the way to . Atleast that's what I had done to my #6 heads just a little bowl work.
Unfortunately the machine shop did not ask me my plans for this engine. I actually took it to an engine builder who has good connections with a machine shop. Saved about $400 going this way. Anyways, I dropped it off with the valves and springs still in it because I didn't have the tool or remove it so I'm guessing they are gonna do a valve job on that set up. I'll try to see if they can pause the process on the heads so I can do some more research on parts.
Coppercutlass, I know you helped me on this topic befor. I still have the message you sent me with the size of valves your using. When I started digging, I found out I would needs a good amount of work done to run those, work that I didn't ask for on those heads. I only asked to have them ported and polished a little. I'm going to go with roller rockers now so I'm going to have to add work to them so I might as well just go ahead and have them set up for bigger valves
My main focus on this thread was to find out what's the biggest size valves I can use if I kept it stock or if the work is something I can do at home fairly easy considering I never did it befor.
Valve size
https://classicoldsmobile.com/forums...echniques.html
ChefDeadpool
August 29th, 2011 12:29 PM
Longhorncutlass
March 2nd, 2009 01:53 PM
