Will stock valve covers work with 3/8" spacers?
Old January 5th, 2014, 04:20 PM
ROBZ442's Avatar
I am looking at my options for valve covers on my build. Will stock style valve covers clear roller rockers, Harland Sharp, Howards, etc... with 3/8" spacers? The 3/8" spacers would allow me to leave my large power brake booster in place. They offer 3/4" spacers but they would interfere with my booster. If I end up changing the booster this will open up a lot more options.
ROBZ442 is offline
Old January 5th, 2014, 05:05 PM
jensenracing77's Avatar
There are alot of threads on this. From what i understand, All roller rockers will fit under stock covers as long as you use the short poly locks. I know first hand the Harland sharp shaft mounted rockers will fit.
jensenracing77 is offline
Old January 5th, 2014, 05:23 PM
ROBZ442's Avatar
Sorry for not searching first. Thanks for the information.
ROBZ442 is offline
Old January 5th, 2014, 06:25 PM
No need to be sorry, I do the same thing. I only find what I am looking for in the search about 25% of the time.
Old January 5th, 2014, 06:50 PM
1970442's Avatar
I have holley valve covers on with baffles removed and harland sharp roller rockers never changed the poly locks but have double gaskets on with no problem.But i did go to a 9" brake booster.
1970442 is offline
Old January 5th, 2014, 06:58 PM
I have 3/8 spacers under my stock valve covers with my Edelbrock heads. I'm using Crane rocker arms. I tried double gaskets, the spacer is a much better solution in my opinion. My brake booster is a little smaller than a stock A body booster but there is plenty of room.
matt69olds is offline
Old January 5th, 2014, 07:58 PM
ROBZ442's Avatar
This is good news and it will save me a little money in the process. I will be running aluminum heads so they shouldn't stand out too bad.
ROBZ442 is offline
Old January 22nd, 2014, 10:33 AM
seansolds's Avatar
I'm using the steel magnum tip roller rockers under stock size morose valve covers with single cork fel pro gaskets and using poly locks with one poly lock removed from each side of engine near the baffle..works great if you want to keep the stock valve cover appearance.
seansolds is offline
Old January 22nd, 2014, 11:14 AM
steverw's Avatar
Who sells these spacers?
Steve
steverw is offline
Old January 22nd, 2014, 06:02 PM
Wise Performance's Avatar
Steve
We offer the 3/8 spacers used for roller rockers and stock style valve overs. $129.99
Wise Performance is offline
Old January 23rd, 2014, 02:27 AM
507OLDS's Avatar
There is also a company that is making factory appearing valve covers,but taller. I used a pair on an engine with rocker stud girdles,and they cleared.They also cleared the large factory booster,but that was a 68-72 set-up. Not sure how different the 64-67 is.
The majority of the roller rockers will clear the factory valve covers,but just removing the baffles,and possibly using 2 gaskets. I have done this numerous times with the factory notched valve covers.
507OLDS is offline
Old January 23rd, 2014, 05:54 AM
ROBZ442's Avatar
That's the route I went, I received my pair of 3/8" spacers on Monday. They look very nice but will require a little material removal to clear the lip on my stamped steel valve covers, easy fix or could run double gasket.
Thanks for the quick service.
ROBZ442 is offline
Old January 28th, 2014, 12:43 PM
Rob,
Thank You for the kind words.
Our spacers fit perfectly on most aftermarket valve covers, some require a little massaging.
Brad @ WPE
Old January 28th, 2014, 05:03 PM
cutlassefi's Avatar
For the umpteenth million time, shorter poly locks will help a lot. Most times you can get by with just using an extra gasket.
cutlassefi is offline
RAMBOW
March 20th, 2017 06:58 PM
Daverd
March 10th, 2014 05:46 PM
JOHNNYOLDS442
June 27th, 2012 10:11 AM
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
Quick Reply: Will stock valve covers work with 3/8" spacers?
