Roll pins in pushrods?
Old Jun 11, 2012 | 04:53 AM
ihengineer76's Avatar
One thing I have noticed a couple times is some people suggested using a small roll pin in the bottom of your pushrod as an alternative to the oil restricting ones available. To me, this seems like a bad idea, because in all my years of farming I know that roll pins will inevitably break or fall out. Has anyone used this or had any success? Maybe horror stories?
Thanks much.
Tom
Old Jun 11, 2012 | 07:19 AM
Run to Rund's Avatar
I agree. If you need restricted pushrods, buy them. Stuffing anything in pushrods usually ends in the stuffee coming out later. If the lifters are correct, metering oil as they should, you don't need them. Generic Chevy lifters are the usual problem with low oil pressure.
Old Jun 11, 2012 | 03:35 PM
380 Racer's Avatar
Saw a guy use pipe cleaners in the pushrods. Worked but after a while the "fuzzies" started going thru the engine.
Old Jun 11, 2012 | 06:54 PM
ah64pilot's Avatar
I have a set of 3/8" Oil Restricting pushrods 9.8" long if anyone wants them. They are brand new...$200
Deputy442
Sep 11, 2008 11:00 AM
iuhoops83
Aug 12, 2008 09:08 PM
dyscookn
Feb 16, 2007 12:24 PM
docjcwatson
Jan 10, 2007 02:46 PM
polcatt
Oct 8, 2006 07:03 PM
