1972 delta 88 2d street strip car
Old October 31st, 2016, 06:57 PM
72delta88's Avatar
looking to build my 72 delta 88 into a street strip car any pointers
72delta88 is offline
Old October 31st, 2016, 08:45 PM
66 POST's Avatar
66 POST is offline
Old October 31st, 2016, 09:20 PM
Lose the low compression 350-2bbl engine with the 4bbl adapter for starters.
You'll need a 455 or similar engine with massive low end torque to get all that pig iron rolling.
Fun71 is offline
Old October 31st, 2016, 10:36 PM
72delta88's Avatar
planned on it the ball an chain left so I can race again
Old October 31st, 2016, 11:04 PM
Chevy budget Olds powered
coppercutlass's Avatar
You will need a big block for sure. Loose weight anywhere you can. Just depends how serious you wanna get.
coppercutlass is offline
Old October 31st, 2016, 11:25 PM
72delta88's Avatar
it does 14s in the quarter I'm shootin for 9s
Old October 31st, 2016, 11:47 PM
9's with that tank you better have deep pockets it takes more than just the hp to make it boogie down the track.
Im not going to be a debbie downer but i doubt it does 14's in the 1/4 with a small block.
Old October 31st, 2016, 11:52 PM
72delta88's Avatar
hey I was goin down hill lol
Old November 1st, 2016, 06:11 AM
66 POST's Avatar
Monster Garage
I can give you an example ------ We did the blue Cadillac 4 dr.Sedan De Ville over twenty years ago that raced Jesse James on Monster Garage. 496 Olds stroker motor , ATI 400 turbo , 4.10 nine inch Ford rear. Street driven 4600 lbs. 10.80s @ 122 . ------
66 POST is offline
Old November 1st, 2016, 08:29 AM
oldsmobiledave's Avatar
into the 9s
Taking it from 14s to 9s will require a significant investment of time & cash.
Big block for sure. Spray will make it happen sooner. Good Luck.
oldsmobiledave is offline
Old November 1st, 2016, 03:26 PM
Kennybill's Avatar
Putting one of these boats into the 14s is very good. Gearing is your friend. 4.10's. You need a healthy fresh 455 with good flowing heads. Cutlass headers will fit but on the drivers side the tubes need to be heated and bent down a tad. I would use an engine plate at least on the front to keep the block from flexing. If you want to get real serious you will need a rear engine plate also. Heavy car to get moving, build for torque. Plan out your "battle plan". I'm not sure of the amount of torque the stock drive shaft and/or the axles will handle. My turquoise 98's best was 14.13 @ 100 mph. It weighs 4680# without me. The pre 1971 B/C body cars are rear steering that may headers non existing. Gearing is limited, I have a 3.08 posi. The engine has gone 11.50s with a different camshaft in a G-body. The launches are hard on the block and it had a main bearing problem and I don't put slicks on it anymore. One thing for sure is you'll be the only 1972 Delta at the dragstrip. Good luck.
Kennybill is offline
Old November 1st, 2016, 09:29 PM
Kennybill i just gotta say love the spokes. the cherry on top for me would be vouge tires.
s i 442
August 2nd, 2013 10:03 PM
rktolds
November 30th, 2011 08:02 AM
anthonylenhardt
March 29th, 2007 07:54 AM
anthonylenhardt
March 28th, 2007 11:30 PM
<johnny5>
Cars Wanted
August 25th, 2005 12:46 PM
Quick Reply: 1972 delta 88 2d street strip car
