Need a Switch...73 Delta 88 conv top
Old Dec 2, 2007 | 06:02 PM
arnyishere's Avatar
1967 Delta 88?
I am in need of a convertible top switch for a 1973 Delta 88.
Old Sep 29, 2009 | 04:46 AM
dedsleds's Avatar
i am getting a 73 olds convert w/power top. email adedhed2@comcast.net
Old Sep 29, 2009 | 05:28 AM
Lady72nRob71's Avatar
Even if you get a new switch, the old one may be repairable. The 72's are easy to repair, yours may be the same if physically intact. Usually the contacts inside get burned and need repolishing. And since it does not work anyway, why not try! Spares are nice to have.
Old Sep 29, 2009 | 08:24 AM
rocketraider's Avatar
Oldsdruid
My luck repairing that switch was "not too good!" I think I got the last NOS one in GMPD system some time around 1995, or so the dealer said. After a couple years even it worked only marginally better than the original.
If cleaning/repairing doesn't work, go to any good electronic supply and get a SPDT (single pole, double throw, ON-OFF-ON) spring return toggle switch and its faceplate. I had one of them on my 73 for a couple years until I decided I HAD to have the OE switch, and it worked great. I found one with a paddle, cut its underdash bracket down to fit flush on the dash, and then used dry transfer lettering to duplicate the factory switch. Solder some 12 gage leads to the switch, then use bullet male connectors to connect the new switch to the harness. Odds are it will work as well as or better than the chintzy OE switch.
As is said, necessity is the mother of invention!
Old Oct 9, 2009 | 10:19 AM
dedsleds's Avatar
i have one
66olds98conv
Ninety-Eight
Mar 21, 2013 12:52 PM
Delta88Vert
Aug 12, 2012 11:39 AM
The_German
Aug 28, 2011 08:18 AM
StickW31
Feb 23, 2010 08:10 AM
