wtb: rear window defogger switch
im looking for a rear window defogger switch for my 66 442, when the guy took the car apart lost the switch, i have the bezel and everything else. ive been told they used the switch in other applications thanks rod
Hi Rod
I think we'd talked before on this topic, but I lost track of your message! I've got a couple single rocker switches from a 1967 that may or may not be the same. I'll be working on the car stuff today and will get some pictures posted for you to check out. John
I have a complete switch with bezel and leads with plugs that came from a full size car if they are the same. It is part number 386602. Group 9.778 in the parts book does not show Cutlass. If you think it might work, send me a PM and I will post a picture. Bruce
Hi Rod
I've come up with two switches but I believe these are only on and off, not the two speed that you need. I've got some double switches that have multiple settings but so far have not found a single with it. If the appearance of one of these is correct please post that so others can see what your looking for. John
