Shifter Stick for 1972 Oldsmobile Cutlass Surpreme
Old January 22nd, 2017, 04:33 PM
LJ72Cut's Avatar
Looking for a new chrome Shifter Stick(Lever) for a 1972 Olds Cutlass Supreme.
LJ72Cut is offline
Old January 22nd, 2017, 06:15 PM
jensenracing77's Avatar
Automatic T handle style?
jensenracing77 is offline
Old January 23rd, 2017, 05:43 AM
LJ72Cut's Avatar
Here is a pic of the original.
LJ72Cut is offline
Old January 23rd, 2017, 06:14 AM
LJ72Cut's Avatar
The guy told me that it broke when he was trying to put it in gear and when he went to fix it appeared that it broke in the past and someone tried to fix it by trying to weld it. But he said that wasn't going to do any good because it was "pop metal" and would have broken eventually. So, he decided to put a bracket on both sides to fix it but I wanted a new one in case this issue happens again. But jensenracing77 I'm not sure what a "T-handle" style is. But yes the car is an automatic.
LJ72Cut is offline
Old January 23rd, 2017, 07:11 AM
When it is correct it has a little T under the ball. I may have one but not sure. I will look when I get home.
Old January 23rd, 2017, 08:08 AM
72 Olds CS
RetroRanger's Avatar
Those are fairly common and not to uncommon to break, 71-72 are the same 69-70 have the same body but a different pressed in pin to accomadate the NSS if Eric doesn't have one check w oldspackrat he has lots of parts.
I agree you should replace that piece now, then if the next one breaks you replace it short term w the repaired one.
RetroRanger is offline
Old January 23rd, 2017, 09:03 AM
72allblackcoupe's Avatar
If Jensenracing77 cant help you I have one in good conditions.
72allblackcoupe is offline
Old January 23rd, 2017, 05:00 PM
I thought I had an extra but I don't. I have a complete shifter but not the lever by itself. If one of the other guys have one go ahead with them.
Old January 24th, 2017, 01:47 PM
LJ72Cut's Avatar
Do you have a picture of it?
LJ72Cut is offline
Old January 24th, 2017, 01:48 PM
LJ72Cut's Avatar
Do you have a picture of what you have?
LJ72Cut is offline
Olds442redberet
April 11th, 2016 04:07 PM
BobertMont
November 26th, 2014 07:36 PM
1k442
Cars Wanted
July 10th, 2014 12:15 PM
MISTERAMAZING
July 16th, 2011 09:55 PM
manitu
May 9th, 2008 11:32 PM
Quick Reply: Shifter Stick for 1972 Oldsmobile Cutlass Surpreme
