TH400 Connector For a 70 442 And Plastic Ring Gear Cover
Old April 7th, 2014, 04:43 PM
costpenn's Avatar
TH400 Connector For a 70 442, Plastic Ring Gear Cover & More
Need the molded connector and about six inches of wire on both leads for the kickdown/TCS switch on the transmission. It is a unique connector - see pic of what specifically I need.
Also still looking for an excellent used trans cover. No cracks or deep scratches.
Added as well the following parts:
OE headlight trim retaining screws. Need - 9 they are really funky looking.
One RH front bumper support long tube. Let me know if you need a pic for comparison
costpenn is offline
Old April 7th, 2014, 09:13 PM
costpenn's Avatar
See above for some more needed parts
costpenn is offline
Old April 8th, 2014, 09:28 PM
2blu442's Avatar
It may take me a few days to come up with them, but I've got:
Bumper Support
Headlight trim retaining screws
Should have the transmission plug, need to check
Did 1970 have the metal or plastic inspection cover? I know they changed around that year, but thought I'd pulled a metal one off a 1970 in the past. Maybe it had been changed before I got it?
John
2blu442 is offline
Old April 8th, 2014, 09:40 PM
costpenn's Avatar
John, it is a plastic one. Let me know. The one I am needing the soonest is that 2 wire molded connector.
Joe
costpenn is offline
Old April 13th, 2014, 02:21 PM
2blu442's Avatar
Hi Joe
I've come up with the transmission cover, grimy but no cracks or bad scratches. The bumper support and the headlight ring screws. The screws have a rust surface on them so they'd need cleaned up too. I'm not sure what kind of finish they had from the factory.
Over the years I've parted out 3 1970's and I'm sure I kept the wiring harnesses. But I've not been able to come up with any of them! I'm still looking, but if someone else has a good plug you'd better get it from them. I'll post pictures this afternoon of the items I have found.
John
2blu442 is offline
Old April 19th, 2014, 11:51 AM
2blu442's Avatar
Just to make sure, are you needing the longer tube that runs from the frame to the corner? Or the longest tube running from the center right of the bumper to the frame? Here's a picture of what I'm calling the longer tube from the frame to the corner.
2blu442 is offline
Old April 20th, 2014, 06:25 AM
crazy'boutOlds's Avatar
if John can't help with the connector, I have one.
crazy'boutOlds is offline
Legos
Drivetrain/Differentials
February 19th, 2015 05:43 PM
oldspackrat
August 10th, 2014 10:03 PM
costpenn
May 10th, 2013 06:11 AM
TRW
January 21st, 2011 05:38 AM
Quick Reply: TH400 Connector For a 70 442 And Plastic Ring Gear Cover
