blower resistor connector for AC cutlass
Old November 3rd, 2013, 03:16 PM
crank shaft's Avatar
Hello, I have been searching for a blower resistor connector for about 10 years and cant seem to find one. My car is a 1970 cutlass supreme. I will try to post a pic.
Thank you, Mike
crank shaft is offline
Old November 3rd, 2013, 03:40 PM
Ten years? It's a standard Packard 56 connector. Tons of them in junkyards, and you can buy them new, too.
You can get them new here.
Those same connectors were used on almost all GM cars with A/C for a large number of years.
MDchanic is offline
Old November 3rd, 2013, 03:49 PM
blower resistor
I have been to junk yards, this one is different. All of the ones I found have the pins in a straight line. Mine has one turned sideways. If I could figure out how to upload a pic I will post one.
Mike
Old November 3rd, 2013, 04:07 PM
It's not this one, is it?
MDchanic is offline
Old November 3rd, 2013, 04:09 PM
Lady72nRob71's Avatar
If your car has AC, then the connector is available at rockauto for about 5 bucks, which is the one Eric lonked to above.
Lady72nRob71 is offline
Old November 3rd, 2013, 04:32 PM
blower resistor
No that's not the one, Mine has 3 pins that go sideways and one pin that goes up and down
Old November 3rd, 2013, 04:34 PM
Okay. I'm stumped, then.
You sure there isn't something weird about your resistor?
MDchanic is offline
Old November 3rd, 2013, 04:50 PM
blower resistor
I will try to post a pic again, Here is the pic of the resistor,
Old November 3rd, 2013, 05:02 PM
Someone on here will have one.
Easy enough to let them know that you're looking for one that goes: | ||
Meanwhile, there's nothing wrong with using regular ¼" spade connectors.
MDchanic is offline
Old November 3rd, 2013, 05:11 PM
Thank you!
Old November 3rd, 2013, 05:16 PM
Just post an ad in the Parts Wanted section.
Also John (2blu442) , Scott (oldspackrat), and several others are worth contacting directly.
MDchanic is offline
Old November 4th, 2013, 08:35 AM
69442C's Avatar
I have that connector from a junk 69 AC harness. I also have a nice used AC harness too. $5 for the connector, or $25 for the used harness which contains that connector. Plus shipping.
Brian
69442C is offline
Old November 4th, 2013, 09:11 AM
I'm pretty sure that's the wrong plug.
His had four terminals. Yours has three, like a heat-only car.
MDchanic is offline
Old November 4th, 2013, 09:23 AM
69442C's Avatar
It's the correct plug. On 69 and 70, which use the same resistor he showed, there is a 3 wire connector and the 4th connector gets a single wire by itself.
Brian
69442C is offline
Old November 4th, 2013, 10:50 AM
Oh.
That's an easy one. From his description, I thought it was a four-terminal plug, which is a whole different story.
Does it look like this, then?
$1.65 a piece from Performance Connectors.
MDchanic is offline
Old November 4th, 2013, 11:27 AM
69442C's Avatar
It looks similar to it but without dimensions its hard to say for certain if that one would work. The original plug does not have a locking tab on it but if the terminal layout was the same then tab would not cause an issue.
If he thought the original design was a 4 terminal plug, I guess that would explain the 10 year search.
Brian
69442C is offline
Old November 4th, 2013, 12:21 PM
Should be the same - all of the Packard 56 connectors are standardized.
If he was a stickler, he could cut the tab off with a razor knife.
It comes in black, too.
Originally Posted by crank shaft
... this one is different. All of the ones I found have the pins in a straight line. Mine has one turned sideways.
Sure sounds to me like he's looking for a single connector with four pins.
We'll see. Hey, Mike, you still here?
MDchanic is offline
Old November 4th, 2013, 01:52 PM
69442C's Avatar
- Eric[/QUOTE]
I can tell you with 100% certainty that the original design did not use a single connector over those 4 terminals. Even the CSM shows a picture that while a little hard to see, does show 2 plugs to deal with the 4 terminals. 68-70 uses the same equipment and I have restored a few 69's, both with AC and parted several with AC too. It's a 2 plug design.
69442C is offline
Old November 4th, 2013, 02:09 PM
Yeah, I saw the CSM illustrations, too.
I agree that two plugs makes more sense.
I've had 2 '68s and 3 '70s with A/C, and it sounds like what I remember through the distant mists of time.
MDchanic is offline
Old November 4th, 2013, 02:58 PM
Ok, I will check the connector on the car. I will post a pic.
Thank you,
Mike
Old November 4th, 2013, 03:52 PM
jag1886's Avatar
I think 69442c has the right plugs. That resistor uses 2 plugs not one.
jag1886 is offline
Old November 4th, 2013, 04:16 PM
OK I feel like a real idiot. Eric I do have the gray one. I purchased this car with the AC stripped out 10 years ago. I located all of the parts out in California and had them shipped to me. Trouble is they packed the compressor with the evaporator core box and broke it. I called and they sent me another one and knowing the plug was melted I pulled the one out of the broken box and have been in search of the wrong plug for a long time, I'm sorry for the confusion. Now I don't know if the box is out of a 70, 71 or 72 Cutlass. Can anybody tell me if this is the correct box by this the connector.
Sorry, Mike
Old November 4th, 2013, 06:28 PM
Okay, now it's starting to make sense.
The resistor you pictured below is from a '68 - '70 car.
The plug I pictured should fit it just fine, but not that one terminal that's hanging out away from the others, which gets a single terminal plug.
Just get a plug for whatever resistor fits in the hole in your evaporator housing.
MDchanic is offline
Old November 4th, 2013, 07:01 PM
Ok cool, I have the resistor with all straight pins None sideways, it would be the first pic posted. Sounds like thats not correct for 70. So Imay have installed a box for a later model, right?
Old November 4th, 2013, 08:40 PM
Right. No big deal, unless you're the 100 point restoration type.
MDchanic is offline
Old November 5th, 2013, 03:04 AM
Old November 5th, 2013, 03:06 AM
Ok cool, thanks for all the help guys. This is a great site.
Old November 5th, 2013, 03:22 AM
You're welcome.
MDchanic is offline
snookys71olds
February 21st, 2012 09:07 PM
redvettemike
September 6th, 2010 07:06 PM
MJAKS462
July 22nd, 2010 03:44 PM
mmcilroy
January 25th, 2010 04:03 AM
jeffreyalman
May 20th, 2009 01:13 AM
Quick Reply: blower resistor connector for AC cutlass
