7028250 - '68 350 carb
Old May 4th, 2011, 05:50 AM
Indy_68_S's Avatar
Looking for either a freshly rebuilt/restored or nice core.....A date code in the 0908 - 1108 range would be nice !
Thanks....
Indy_68_S is offline
Old July 7th, 2011, 02:02 PM
Indy_68_S's Avatar
Bumpity...
With all the SBO rebuilds, I know someone out there has one ! Go check that shelf in your garage !
Old August 15th, 2011, 06:29 PM
Indy_68_S's Avatar
Comin' around the horn again.......!
Old August 15th, 2011, 07:12 PM
mmcilroy's Avatar
I just pulled this 350 out of a 68 two weeks ago. It's a good running engine. I was going to rebuilt it but date code does not matter to me, I have another carb I could use. Here's a picture of the numbers except I don't see or don't know where to find the date code?? Where does one find a date code? If I can find it maybe I can help you out.
mmcilroy is offline
Old August 15th, 2011, 07:15 PM
mmcilroy's Avatar
Forgot the picture....
mmcilroy is offline
Old August 15th, 2011, 09:03 PM
Indy_68_S's Avatar
Thanks mmcilroy!
There may not be a date code stamped by the number itself..on '68s I think it was down by the drivers side rear mounting hole on the base
PM sent with/for more info....
Old March 5th, 2012, 04:23 PM
oldsmobuser's Avatar
Hey mmcilroy ! Do you have a set of #5 cyl. heads you don,t mind parting with ? If you do please let me know. Thanks.
oldsmobuser is offline
Old March 5th, 2012, 04:26 PM
The date code is usually right below the carb number but I don't see one in your case.
Old March 6th, 2012, 11:59 AM
mmcilroy's Avatar
Just saw your post about the heads, I'll PM you this evening
mmcilroy is offline
Old March 13th, 2012, 07:46 PM
Octania's Avatar
on 1968 carbs, the date code is in the BASE, LH side, aft corner.
I currently have a body, rebuilt, on ebay. Can get whole carb, rebuilt, various date codes, $300 delivered USA
Chris
Octania is offline
Old October 11th, 2021, 09:09 PM
Hey mmcilroy, I know this is an old post. Did you sell your 7028250 '68 carb? Any word on those heads? Thank You, Sir. Have a great day.
yeahbuddy
August 1st, 2013 03:19 AM
RandyS
October 4th, 2012 12:36 PM
yeahbuddy
May 17th, 2011 09:51 AM
yeahbuddy
October 28th, 2010 09:06 AM
dharlett
September 23rd, 2009 03:30 PM
Quick Reply: 7028250 - '68 350 carb
