67 442 SS1 rims
Old February 7th, 2024, 12:27 PM
89biff's Avatar
67 442 SS1 rims
Long shot….
looking for 14” ss1 rims for 67 442 with factory disc brakes.
89biff is offline
Old February 7th, 2024, 12:36 PM
Giftman23's Avatar
Wasn’t aware of a factory 14 inch SS1 available thar would fit discs in 67 - Someone with more knowledge (and perhaps a PIM chart) will chime in - I thought 1969 Ly code 810 rims were the first available SS1’s that would fit discs. Now, if you wanted to go 15’s with red line radials I have a brand new set (not cheap) - only mention since I am local to you. Good luck.
Giftman23 is offline
Old February 7th, 2024, 12:46 PM
Rocket Renegade!
Nope, no SS I's with discs in '67. If your heart's set on discs with those wheels, Wheel Vintiques or another specialty supplier is probably your best bet. Either that or scout the farthest reaches of E-bay for a set of late '69 SS I's -- IIRC there was a running change made during the model year to accommodate disc brakes. However, if you find these, they will likely be quite expensive.
BangScreech4-4-2 is offline
Old February 7th, 2024, 01:12 PM
Here is a SPECS excerpt. There ain't no such animal as a SSI that will work with power disc in 67. P01 was the only option for power disc brakes, and you got a special wheel that could clear them that was a stamped steel poverty cap wheel.
As said above, for factory disc on 67 to use a SSI, you need a set of any of the following:
-1969 SSI 14x6 all chrome, 810 rims
-ALL SSI 14x6 with beauty trim ring rims
-ALL SSI 14x7 1971 all chrome rims
-or any aftermarket that is advertised as fitting.
Koda is offline
Old February 7th, 2024, 01:19 PM
89biff's Avatar
Alright then. I misread someone else’s post about special rims for factory disc brake. Assumed it was a special ss1.
moving on. Thanks all.
89biff is offline
Old February 7th, 2024, 01:33 PM
66SportCoupe's Avatar
There was a special disc brake SSI but it came only in late 1969.
66SportCoupe is offline
Old February 7th, 2024, 04:39 PM
442crzy's Avatar
I have a set of 4 original all chrome 14x7 SSI wheels from a 1971 442 if interested PM me.
442crzy is offline
Old February 8th, 2024, 07:14 PM
Yacht Machanic's Avatar
I have a set of 14x6 SS1 disc brake wheels in Fair condition. No clue to date of manufacture. Will dig one out tomorrow and see what is stamped on them.
Yacht Machanic is offline
Tom
August 27th, 2015 03:53 PM
JasonTou
May 30th, 2015 11:37 AM
jim larson
June 13th, 2013 07:08 PM
ddx77
Wheels and Tires
July 4th, 2011 03:32 PM
R&B67Cutlass
Wheels and Tires
August 17th, 2010 09:35 AM
Quick Reply: 67 442 SS1 rims
