W30 Stripes
Old September 25th, 2009, 04:49 PM
stevengerard's Avatar
W30 Stripes
OK since Joe brought up the W36 stripes how about some W30 stripes. Talk about a work of love to get these things correct. The stencils that are sold are of great help but we ended up tweaking all of them except the hood stencil. We had to tweak it over the wheel wells, and around the deck lid. I used measurements from original paint jobs to get these correct and not surprising many were different, especially the height of the stripes from the bottom of the car as well as the curve around the wheel wells. I'll post some pics, let me know what you all think - its too late to change them so all comments welcomed - by the way I am very happy with how they turned out
stevengerard is offline
Old September 25th, 2009, 04:54 PM
here is the car masked off for painting of the stripes
Old September 25th, 2009, 04:59 PM
I'm glad you're happy with the way they turned out. The pattern and precise measurements for the hood stripes in contained in the Cutlass assembly manual for your model year.
Don't keep us in suspense now, rrriiipppp off that masking and lets see how your baby turned out.
Allan R is offline
Old September 25th, 2009, 05:07 PM
Unhappy
Here are some stripes after the stripes were applied and before the clear coat. I elected to have them sand the stripes and then clear coat - some folks would have gone with the stripes over the clear coat to give the stripe a raised feeling like the originals and then apply another clear coat over it all.
The big challenge was the curve right after the W-30 emblem and before the front wheel well along with the curve on the quarter extensions, the stencil did not work well either place. We had another challenge as the shop threw away what was left of the original fenders so we had to measure and measure and test and test where the W-30 emblems went. The original fenders had the holes punched - should have kept the old fenders and dealt with the extra work to fix them up
Old September 25th, 2009, 05:09 PM
Yep, we used that too!
Old September 25th, 2009, 05:17 PM
here is the car in the paint booth drying after the first coat of clear - I'll add more pictures to my restoration thread. The most inconsistent obvious error that I usually see with these strips is the front fender stripe level. It goes up with the body line, many people keep it parallel to the ground. Of course we have all seen many variations from too thin of top line, too much space between stripes, thin line rapping all around the hood stripe, hood stripe going all the way to the back trim etc.
Old September 25th, 2009, 06:00 PM
Steven,
Beautiful job.
While I'm whining about stripes, there are the folks who insist on painting W-30 stripes on non-W-cars...
joe_padavano is online now
Old September 25th, 2009, 06:07 PM
Steven,
Beautiful job.
Thanks Joe, that means a lot coming from you - its nice to be back on this forum as I finally have some time - I remember in the old days waiting for replies from you and the other experts in the early days of the list serve.
Old September 25th, 2009, 08:10 PM
Very nice looking car. It should be a knockout when it's done. I'm guessing the interior and top are going to be white?
Allan R is offline
Old September 25th, 2009, 09:27 PM
Thanks!! Yes, those pics to come soon.
Old September 26th, 2009, 12:39 PM
While we're talking about W-30 stripes, I happened to pass a white 1970 "W-30" on the way to work this morning. I used quotes because the stripes were not exactly correct and the W-30 emblems were too far down from the 442 emblems (and not parallel). The car did have red inner fenders, but since the was on the road I obviously couldn't tell if they were real or repop.
Old October 22nd, 2009, 12:04 PM
1ATony's Avatar
Man was that alot of masking.The car looks great.
1ATony is offline
Old October 31st, 2009, 04:12 PM
70vista's Avatar
Nice job on the stripes and car. How long did you wait between base coat, stripes and clear.
70vista is offline
Old October 31st, 2009, 10:22 PM
not sure, it has been so long, I know between base and stripes it was days but may have only been a day or two between the stripes and the clear coat
Old November 1st, 2009, 02:25 AM
agtw31's Avatar
badly painted stripes will get you a trophy at an OCA meet
i believe it's a requirement(insert smiley face here)
agtw31 is offline
Old November 1st, 2009, 03:58 AM
70vista's Avatar
Thanks for the information. I have been told that the clear should be put on in 24 hours after the base coat. I would like to do the jambs and put the sheet metal on the car and then base and clear the rest but it take longer than 24hrs.
70vista is offline
Old November 1st, 2009, 04:50 AM
Oldsdruid
rocketraider's Avatar
You're badd. You do live up to your name!
When OCA judging gets consistently consistent, I'm bidding on the airconditioning maintenance contract for Hell!
And just think, the factory was doing 60 or more cars an hour when they put the stripes on...
rocketraider is online now
Old November 1st, 2009, 06:53 AM
And my measurements of "original paint" W-30s proved that they were inconsistent at the factory as well. I only had access to a few cars and called a few others who had "original paint" and asked them to measure in a few spots, although close they were all off. The biggest difference was the height of the stripes from the bottom of the doors, this made some of the W-30 emblems end up in the middle of the stripe while others where near the top of the stripe. the distance of the curve from the wheel well was closer but also different and of course where the stripe ended was also off a 1/4 to 1/2 inch from car to car.
Old November 1st, 2009, 07:05 AM
I'll ask the shop tomorrow for you. I know they did my jambs first as well but maybe they sanded them a bit and put another coat of base on but I doubt it.
Old November 1st, 2009, 03:45 PM
Registered Luser
ent72olds's Avatar
Steve, depends on what paint you use....Spies Hecker and Standox has an endless open window! You can do your jambs and clear them 3 years later if you want. Trust me, I know.....
ent72olds is offline
Old November 1st, 2009, 05:49 PM
70vista's Avatar
Thanks for the information. I use either PPG or Dupont ansd they have a window of 24 hours. I would think if you sanded it it would take more base and clear.
70vista is offline
Old November 2nd, 2009, 03:40 PM
Registered Luser
ent72olds's Avatar
Yes it would!
Old November 3rd, 2009, 03:19 AM
BobsW32
Bobsw32's Avatar
Here is a picture from an original car
Bobsw32 is offline
Old November 3rd, 2009, 08:07 AM
thanks for the pic, that is probably the highest I have seen the thick stripe which makes the W-30 emblem sit lower - makes sense that they would vary a bit - will add this to my collection of images so I can build up a reference database for others to use
Old November 3rd, 2009, 08:52 AM
BobsW32
Bobsw32's Avatar
Here are the rest of the pics:
Bobsw32 is offline
Old November 3rd, 2009, 10:31 AM
can you measure from the bottom of the door to the bottom of the large stripe - be curious as to what the height from the bottom of the door is. Thanks
Old November 4th, 2009, 02:46 AM
BobsW32
Bobsw32's Avatar
Steven
These are pictures from some time ago .........The car has been restored..... Maybe someone else has an original that they can measure....
Bob
Bobsw32 is offline
Old November 12th, 2009, 06:29 AM
507OLDS's Avatar
The stripes on teh W-cars is what makes or breaks the car.There are SOOO many cars out there with poor stripes.I've had plenty of opportunities to buy some real nice cars,but when the stripes are wrong,it is a turn-off to me,as I would want to repaint the whole car.I have the same problem here,with my own cars.It takes someone with a special art & a boatload of patience to do the stripes correctly.
I have seen some 100% original cars with the stripe lower/higher than the other side.
Where are you located Steven? I wonder if your bodyman would want to stripe another car,or possibly paint the whole thing?
507OLDS is offline
Old November 12th, 2009, 05:44 PM
70Post's Avatar
Originally Posted by Bobsw32
Steven
Bob
70Post is online now
Old November 12th, 2009, 07:57 PM
I'm right there with you, the W-30 stripes are gorgeous when done correctly and can be horrible when done wrong, but I bet it is more offensive to guys like us who know the stripes so well, as you state even the factory was off many times. I'm in the Chicago area and the guy who actually painted the stripes no longer works at the shop (that's how long it has been there) what made the most difference was spending the money on the stripe patern that the parts place sells and then tweaking it until it was perfect. I measured and re-measured and stood back and double checked and they even recut the pattern - they even made their own pattern for the curves on the trunk - I hate to think how much those stripes alone cost me, and now I'm hitting myself over the head for getting rid of decent 70 fendors and replacing them with the "perfectly new" (bs) 71/72 aftermarket fenders. UGH!!!
70-442-W30
July 30th, 2016 04:27 PM
jcl
Paint
40
December 18th, 2015 02:26 PM
JOHNNYOLDS442
October 2nd, 2012 03:31 PM
jcl
May 17th, 2010 04:54 PM
stevengerard
October 16th, 2008 11:38 AM
Quick Reply: W30 Stripes
