Weatherstripping
Old November 24th, 2015, 02:54 PM
Paxtonshelby's Avatar
Weatherstripping
Hi all - I need a trunk weatherstrip and door window weatherstrip for my '66 Toro. Where do you suggest I go for these parts? Fusick or ? Thanks!
Paxtonshelby is offline
Old November 24th, 2015, 03:15 PM
Metro's got 'em.
MDchanic is offline
Old November 24th, 2015, 04:30 PM
Thanks Eric - I never heard of Metro.
Old November 24th, 2015, 06:20 PM
Yeah, there's Metro, SofSeal, and one other, whose name I forget.
I checked out Metro and SofSeal pretty much right next to each other at a show a few years back, and I liked Metro's parts a bit better, but you'll find various opinions.
MDchanic is offline
Old November 25th, 2015, 06:03 AM
m371961's Avatar
Metro was available thru Rock Auto for my 98. I found the door seals and trunk seal to be of OK quality, but the seals for the quarter window to door seal and the seal in the door jamb lacking. The quality of Steele rubber was better.
m371961 is offline
Old November 25th, 2015, 06:23 AM
RROLDSX's Avatar
I was happy with Metro and it was the best price also.
RROLDSX is offline
Old November 25th, 2015, 10:27 AM
Oldsdruid
rocketraider's Avatar
Metro supplied Fusick at one time. Not sure if they still do. The moulded end caps pulled loose from two sets of Metro door seals on my 69 Toro. To their credit the roofrails and trunk rubber worked well.
I was never too keen on Soff Seal- the rubber "skin" dried out and cracked quickly on all the cars I saw it used on, but that was 20+ years ago.
Steele makes a good quality product. it won't be the cheapest but I've had no issues with any Steele products I've used.
You're aware of the way the E-body roofrail rubber is made and put together, right? You get only the front section above the door glass. The rear part is molded hard rubber and difficult to remove & replace without gutting the interior. You install the new front section and then cover the splice with cloth body tape.
Last edited by rocketraider; November 25th, 2015 at 10:54 AM. Reason: add E-body roofrail comments
rocketraider is offline
Old November 30th, 2015, 11:43 AM
Thanks for the great info guys!
442_Mustang
July 7th, 2018 06:48 AM
Doug69Cutlass
Body work
April 27th, 2009 05:28 PM
DAN76
October 14th, 2008 06:22 AM
Omicron
July 5th, 2008 09:03 PM
Doug69Cutlass
April 15th, 2008 04:50 PM
Quick Reply: Weatherstripping
