Maybe bad gas??
Old July 27th, 2015, 08:22 PM
kfzr2's Avatar
Maybe bad gas??
Hey guys,
Had some weird issues tonight and hoping it might be just bad gas so wanted to see what some of you thought.
Drove my cutlass all day today with zero problems, then i put 91 octane gas from costco in the car today(which is the first time getting gas from here for this car). I then drove it for about 30 min with no problems. Went to a late night movie where the car sat for about 2 hours.
After starting it and going to drive, it wouldn't idle properly and wanted to die unless i gave it gas. I drove it home and kept the revs up at red lights to keep it from dying. The engine was definitely fully warmed up when i got home but it felt as though there was water or something in the gas.
Has anyone experienced something like this after putting gas in from somewhere different then normal? (Usually get 91 octane from esso). Or maybe i didnt let it warm up properly after it sitting for 2 hours? (Even though it still ran rough after the car had fully warmed up? )
70 cutlass with 350 rocket 3 speed auto, 400 quadrajet
kfzr2 is offline
Old July 27th, 2015, 08:36 PM
The timing does sound like water in the gas.
Pull the airhorn and have a look in the float bowl - water sits in the bottom and looks like an odd slippery bubble rolling around down there.
If it is water, then adding a whole mess of alcohol (gas line antifreeze) should get it into solution so you can burn it.
MDchanic is offline
Old July 29th, 2015, 04:42 PM
kfzr2's Avatar
Ended up being some bad gas, put a can of seafoam in and let it run for a bit, filled up at the usual spot with 91 octane and ran like new. Thanks for the info though, now i know what to look for if i suspect water in the gas.
-Kevin
kfzr2 is offline
Old July 29th, 2015, 04:52 PM
MOTORHEAD
11971four4two's Avatar
fuel
i prefer to buy non oxy 4 4 2 m y mower
snow blower
and olds cars too
keep the ethanol out of your olds mo bile
11971four4two is offline
Old July 29th, 2015, 05:10 PM
RandyS's Avatar
snow blower
and olds cars too
Dude, what kind of painkillers are you taking............lol
RandyS is offline
Old August 4th, 2015, 05:11 PM
Bfg
Bfg's Avatar
I also got bad gas last week. It turned out to be the two large burritos I had for lunch. After a hand full of tums everything was back to normal.
Bfg is offline
odddoylerules
April 21st, 2014 07:54 AM
airmale
November 13th, 2013 11:15 AM
442scotty
August 9th, 2011 12:32 PM
scrappie
March 19th, 2009 04:53 PM
berto
August 4th, 2006 10:46 PM
Quick Reply: Maybe bad gas??
