E - brake cable removal
Old July 22nd, 2014, 08:37 PM
I'm indecisive. Or am I..
Napoleon Solo's Avatar
Ok - I give up. is there a trick to getting the e-brake cable through the firewall / frame to free it from the car?? It's the last piece of the puzzle and the body is ready to come off.
It's my '64 cutlass.
Napoleon Solo is offline
Old July 22nd, 2014, 08:55 PM
wls559's Avatar
What part can't you get out? Is it the little bird cage shaped part... If so; from the inside push out, place a box wrench over it to depress the flanges then push and wiggle it through. It's the same as when you take them off of your rear backing plates.
Bill
wls559 is offline
Old July 23rd, 2014, 03:10 AM
Yellowstatue's Avatar
Or use a small hose clamp on the fingers and tap gently with a hammer!
Yellowstatue is offline
Old July 23rd, 2014, 06:48 AM
JohnnyBs68S's Avatar
I used a 6-pt 9/16" deep well socket to compress the fingers and free the cables from my backing plates. I'm attempting to do the same on the cable to the pedal under the dash, but can't quite get the leverage to pull it through. Might need to open the can-'O-hammer next.
JohnnyBs68S is offline
Old July 23rd, 2014, 04:58 PM
Perfeck. I thought perhaps it was a squeeze and push situation - thanks for the tips. No more excuses for me now...
Old July 24th, 2014, 08:17 AM
joe_padavano is offline
Old July 24th, 2014, 08:50 PM
Thanks Joe,
I'll guess O'reillys will have one.
defiant1
February 4th, 2020 08:53 PM
Dead Reckon
Brakes/Hydraulic Systems
16
April 6th, 2015 12:48 PM
rootney
June 27th, 2014 11:30 AM
dmberendsen
April 10th, 2013 03:18 PM
CUT-N-UP
July 10th, 2011 03:53 PM
Quick Reply: E - brake cable removal
