Charcoal canister delete
Old May 6th, 2011, 06:10 AM
Tom Servo's Stunt Double
texasred's Avatar
The car is a 71 Cutlass Supreme 350. If I delete the charcoal canister and plug the line to the standpipe, am I creating a pressure problem (positive or negative) in the tank? Should I change to a vented fuel cap? If so, suggestions on a P/N or suitable substitute?
TIA
C.J.
texasred is offline
Old May 6th, 2011, 07:13 AM
Lady72nRob71's Avatar
I would say yes - you would need a vented cap, as normally the vent would be through the charcoal can. Do not have part #'s though...
Lady72nRob71 is offline
Old May 14th, 2011, 01:58 AM
texasred's Avatar
Has anyone used a vented fuel cap on a 70-72 vintage Cutlass? I figure it "might" leak with a full tank, but I'd like a confirmation one way or the other.
Thanks in advance.
C.J.
texasred is offline
Old May 14th, 2011, 04:28 AM
There's no reason why a vented cap should leak, in and of itself. I can't say for sure whether the filler neck is any different where the cap seals, but I don't think it is.
Getting the right cap should be no problem - just look one up from an earlier car and confirm that it's different from the one shown for your car.
Remember that it is technically illegal to modify or disable any emission controls, so don't do it if you're in a locality where they do emissions inspections (mostly in the more Fascist states, like CA and NJ).
MDchanic is offline
Old May 14th, 2011, 06:04 AM
bonnevillegreg's Avatar
Uhhh...well, actually...
Out here in "fascist" California, model years 1974 and older are smog exempt and don't require inspections for registration purposes.
bonnevillegreg is offline
rhett838
July 24th, 2015 12:23 AM
oldzy
July 1st, 2013 06:55 PM
jbestic
March 26th, 2012 08:02 PM
frasco
August 1st, 2011 09:25 PM
esisson
November 23rd, 2008 10:05 AM
Quick Reply: Charcoal canister delete
