Left rear quarter window
Old June 9th, 2016, 04:59 PM
Stevec's Avatar
My left rear quarter window will not go up correctly/straight while I turn the window crank, I need to grab the window and pull it up to help it while turning the crank.
Do I need new rollers? Does anyone know what the fix is?
Stevec is offline
Old June 9th, 2016, 05:19 PM
therobski's Avatar
Brother I'm going through the same thing on the 64 F-85 Pro-Touring build. One rolls up and down fine, even have the access panels open for comparison's and still cannot figure out why that one-(drivers side)-does not work right. I have the chassis manual too! Got a second pair of eyes coming over this weekend and if we can figure it out I will look up this post.
therobski is offline
Old June 9th, 2016, 05:25 PM
Stevec's Avatar
Thanks Rob let me know what you find!
Stevec is offline
Old June 19th, 2016, 07:06 AM
amesolds's Avatar
I just pulled the rear windows and regulators out of a '70 442 and immediately noticed the lack of lubrication on the rollers and guides. as long as the regulator gears are not stripped, a good lubing with grease of all the contact areas will probably solve the problem. Hope this helps.
amesolds is offline
Old June 19th, 2016, 09:29 AM
therobski's Avatar
Not the problem. When cranking the drivers side, the rollers and regulator is well lubed and in place, the glass will not stay on track-this is a post car. I use the pass side as an example and still cannot figure it out. But for now I'm more focused on getting the car started and tuned-and now its blazing hot out to boot.
Eightupman
February 8th, 2022 07:37 AM
jrmarin
June 3rd, 2014 04:26 AM
HonestDave
May 28th, 2013 08:22 PM
rocket88philbaker
February 2nd, 2013 12:50 PM
1k442
May 10th, 2010 11:30 AM
Quick Reply: Left rear quarter window
