62 Starfire Disappearing Brake Fluid
The master cylinder, booster, lines and wheel cylinders are all new and I have a check valve in the vacuum line to the booster. I had to bleed the brakes several times to get all air out. I also bench bled the master cylinder before I installed it. I drove the car home 8 miles from the upholstery shop with good pedal and brakes on Saturday. Yesterday I pulled it out of the garage. No brakes. Master cylinder is empty. I now thnk thats why I had to bleed the brakes so many times. The fluid is going somewhere and when I step on the pedal I put more air in the system. The wheel cylinders are not leaking.
Bad master cylinder? If so am I filling the booster with
X2 on this, Common problem with cars that set a lot. You can rebuild the master cylinder with a kit and a cylinder hone, very simple task.
cfair
Brakes/Hydraulic Systems
Jun 8, 2009 12:37 AM
