Non-Oldsmobile Classified Please read forum guidelines before posting.
FS:Late 99 F-250 ECSB 4x4 ZF6 7.3 Ohio
Old February 11th, 2014, 02:58 PM
djchunter's Avatar
Late 1999 F-250 XLT Supercab 4x4 7.3 6spd 229k and climbing, SouthBend Single(15k), TS 75hp 150tq Chip, 4" turbo back, BFAF Mod, Autometer factory match egt and boost gauges,2 New injectors,All the Glowplugs and valve cover harnesses in October. Also in October I did rear brakes, backing plates, e-brakes, axle seals and changed both diff's and the T-case fluid's. Last spring the front brakes, hub bearing and front track bar were replaced. Also in the last few weeks the truck also has a brand new starter and alt (not reman) Tires are Pro-comp Xtreme A/T with 10k on them. Truck has been a synthetic rotella truck its whole life. The truck has rust on the bottom of the cab corners, and the bottom of the rear doors. The rockers are still solid. There is a small rust hole on the drivers bed side and the pass side is starting the bubble, The tail gate is from a different truck and the bottom lip is rotted. The truck is super clean underneath. I can provide anymore info or pics just let me know. The truck is located in cleveland, ohio. To cut all BS a side I want $5k firm for this truck. I hate wasting time, mine or others so that's is that. Bring $5k and drive the truck home. Feel free to call of text me at 440-342-2412
Dave
djchunter is offline
Old February 12th, 2014, 12:13 PM
djchunter's Avatar
Sold, lock it up!
ohiocutlassparts
February 4th, 2014 04:55 PM
Stattiolds69
July 21st, 2011 11:02 PM
jensenracing77
December 27th, 2009 02:24 PM
65az
September 11th, 2009 09:59 PM
BIGBAD455
May 7th, 2008 09:37 AM
Quick Reply: FS:Late 99 F-250 ECSB 4x4 ZF6 7.3 Ohio
