Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
64 cutlass radiator
Old June 16th, 2018, 11:32 AM
prohandze's Avatar
64 cutlass radiator
Im looking to buy a radiator but having problems locating the correct one. does anyone know where i can get one? 64 cutlass f85. thanks in advance
i installed a 6.0 LQ9 engine
prohandze is offline
Old June 16th, 2018, 04:13 PM
therobski's Avatar
Prohandze-problem is that I assume you have the 64 only driver inlet water pump.I have a 65 on up water pump (passenger side inlet) on my 64 F-85 with a Champion radiator-that's for a 64-65 GTO. FYI-the radiator core support is 64 only too. 65 core support is about 3 inches deeper. Or re-core the one you have. FYI- I have the 330 drivers side water pump if you need a spare.
therobski is offline
Old June 16th, 2018, 05:04 PM
Gerald Nickels's Avatar
What I did on my 64 F-85 was take the bottom off the 64 core support and install a 65 bottom problem solved. I have a 65 core support I could send the bottom. I just painted the alumn rad. bottom black so it doesn't stand out looking from the front.
Gerald Nickels is offline
Old June 16th, 2018, 07:05 PM
prohandze's Avatar
so you welded a 65 bottom to a 64 support?
Old July 3rd, 2018, 07:14 PM
a64olz's Avatar
That is what i did, I then put in a Champion radiator.
a64olz is offline
Old September 30th, 2018, 01:05 PM
Alex72cutty's Avatar
Any updates?? What trans did you put behind your 6.0 engine?
Alex72cutty is offline
brick
May 7th, 2017 04:07 PM
sbceater
April 3rd, 2015 03:14 PM
therobski
March 22nd, 2015 09:00 PM
sbceater
July 27th, 2014 08:41 PM
Napoleon Solo
April 29th, 2013 10:16 AM
Quick Reply: 64 cutlass radiator
