Heater Core R&R on '70 LS - Anybody done this before?
Old Dec 9, 2008 | 11:08 AM
Oilbrnr's Avatar
How much of the dash needs to be pulled to get to it?
Old Dec 11, 2008 | 11:47 AM
rocwal
Guest
Posts: n/a
70 olds LS heaater
Don.
from what i remember and just looking at my 68 manual u have to remove all compontents to the air and heat box under dash ,defroster, vac lines,routing hoses, etc, mabey the radio , would be easier with it out. then there is 4 or 5 bolts with nuts on firewall side needs to be removed from firewall side,also drain the radiator, remove the heater hoses at firewall and the whole assembly should come into the interior of car . lots of luck.
do you have a manual for the 70 98 ?
Don did you get pictures of the carb breather ?
rocwal
Dan B
Old Dec 11, 2008 | 01:23 PM
Oilbrnr's Avatar
Thanks Dan.
Yes I do have a manual, but I was hoping for tips from anyone that has actually done it before.
It is not like I need the heater all that often down here in Phoenix anyway!
I did get the pics. Thanks.
Old Dec 11, 2008 | 06:21 PM
rocwal
Guest
Posts: n/a
remove heater core 70 OldsLS
Don
.is your heater core leaking or is just not putting out heat ? If it is heat then it may be the valve on the motor not opening or the control from selector inside on dash.
roc wal
Dan B
Old Dec 12, 2008 | 08:33 AM
Oilbrnr's Avatar
No, it was leaking. I bypassed it a couple of years ago. Hopefully I have the correct new one, but I have my doubts as it came from NAPA.
Old Dec 12, 2008 | 08:44 AM
Oldsguy's Avatar
Past Administrator
From my experience I would trust NAPA employees to find a correct part more often than PepBoys, Auto Zone, and even some O'Reilly's although I have found a good local O'Reilly store that has good employees so I am lucky.
2blu442
May 15, 2016 08:17 PM
nightmare
Jun 21, 2012 12:23 PM
ent72olds
Vista Cruiser & Wagons
Sep 25, 2010 02:07 PM
62 Starfire
Nov 25, 2009 10:18 PM
Z3d
Ninety-Eight
Oct 11, 2009 02:58 PM
