Help 74' 98 No turn signals.
Old Jan 30, 2008 | 02:58 PM
h4l420's Avatar
The bar for the turn signals is completely loose and it wont work for turning or cruise control (which I could careless about)
How do I fix this?
Old Jan 30, 2008 | 06:12 PM
Modern Motoring's Avatar
sounds like you need to pull the steering wheel and find out whats broken. Good news is, every thing you need to repair it is available at your local parts store.
Old Jan 30, 2008 | 06:32 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Is the signal lever attached to the column.....
or hanging by the cruise wire?
Old Jan 31, 2008 | 10:02 AM
rocketraider's Avatar
Oldsdruid
Is the car tilt, tilt-telescopic, or non-tilt? all attach to the t/s actuator differently. Tilt and non-tilt attach to actuator with a screw and you have to pull the steering wheel and lock plate to get to it. Tilt/tele screws into the actuator.
Old Jan 31, 2008 | 10:30 PM
h4l420's Avatar
Ok thanks guys I think I got it just got to take apart the steering colum
projectheaven
Aug 17, 2008 08:58 PM
palmers65
May 30, 2008 11:12 AM
cola
Mar 21, 2008 03:44 PM
wizzy01
Nov 20, 2007 04:03 AM
falconsfan
Mar 19, 2007 04:58 PM
