Engine RPM at Highway speed??
Old Sep 12, 2011 | 07:01 PM
66ninetyeightls's Avatar
Land Yacht Captain
Can anyone with a 66 Ninety Eight or similar full size tell me what engine RPM I should expect to see at 60MPH(100KPH)??
I just got a new tach and its reading close to 5000RPM at that speed. I know that is WAY off and the tach is bad. I just want to know what I should be looking for when I install the replacemnt tach.
Old Sep 12, 2011 | 07:13 PM
I don't have the specs at my fingertips, but I believe that a stock '66 should have anywhere from a 2:56 to maybe a 3:31 gear, so 5,000 RPM @60mph is out of the question.
Does the tach have a selector for number of cylinders?
Is it connected to the negative coil terminal (the one that goes to the points)?
Old Sep 12, 2011 | 07:16 PM
Land Yacht Captain
Yeah its set to 8 cylinder and is connected to the coil negative. I'm pretty sure its just a bad tach as it was pretty cheap 2" unit.
Old Sep 12, 2011 | 07:27 PM
72 cutlass455's Avatar
Think it would be 2250 to 2600 could be as high as 3000 but would think it would be some where in that range.
Old Sep 12, 2011 | 08:23 PM
AZ455's Avatar
1974 DELTA 88
Not sure if this will help, but my Eighty-Eight turns around 2500 rpm @ 65-70mph.
Old Sep 12, 2011 | 10:02 PM
Jaybird's Avatar
Craig: My '67 Delta 88 has a 3.08 rear end. I had my tach recalibrated last year. It reads between 2500 and 2600 rpm at 60 mph. I run the correct diameter tires, 235/70/15 (28").
Jaybird
Old Sep 13, 2011 | 12:00 PM
Land Yacht Captain
Great thanks. I will check it out once I have a decent tach installed.
Old Sep 13, 2011 | 12:10 PM
VikingBlue's Avatar
Craig ... did you ever take your 11 x 5 inch wheels off the car ?
Old Sep 13, 2011 | 12:18 PM
Land Yacht Captain
You mean I can't run wheels from a Mini Cooper?
455man
Wheels and Tires
43
Jun 13, 2012 02:50 PM
cnewp000
May 28, 2010 05:55 AM
Oldsmaniac
May 26, 2010 10:18 AM
AZ442
Oct 31, 2009 05:06 PM
gillbates
Sep 18, 2009 10:57 AM
