What lurks under the window rubber
Old May 3, 2009 | 11:39 PM
56oldsnub's Avatar
Pulled the rear window out of my 56 98 this weekend because I had a sneaking suspicion there was some rust under there. Not nearly as bad as I thought.
Old May 4, 2009 | 08:14 AM
citcapp's Avatar
Not bad at all as he sigh's with relief
Eric Anderson's Avatar
Doesn't look too bad. Are you going to weld in some small patches to fix it up?
Old May 4, 2009 | 10:44 AM
56oldsnub's Avatar
Yes there was a bit of a sigh of relief when I saw that it was less than I thought
I don't think it's big enough to go with a patch and there's no 'structure' worries. I may just use a little brass rod and fill the cracks. I still have to get up underneath and see what kind of rust is on the underside. If it's not too bad, then I'll fill it...if it looks like it needs a little more I'll put a small patch in.
I'll keep you posted
Old May 4, 2009 | 11:26 AM
Good deal that'll work. Do you use gas to braze or a tig torch? I've always used gas myself but am curious how tig works out.
Old May 4, 2009 | 06:57 PM
56oldsnub's Avatar
I still use gas as well...I think it's easier to get into those tougher areas
Rickman48
Mar 23, 2013 01:06 PM
matchek
Sep 27, 2012 01:13 PM
doxchopshop
Jul 17, 2012 09:19 AM
defiant1
Jul 10, 2011 07:41 PM
CANVASWING
Apr 21, 2010 08:24 AM
