Cross Member
Old Oct 21, 2009 | 08:24 AM
abram's Avatar
Cross Member
Put a 403 with a TH400 into a 1977 Siverado, The crossmember for the tranny will work with a bit of shuffling, the question I have is, the crossmember is the type that has a Y looking ends, the top section of the Y is bolted downwards from the frame, I am going to have to move the xmember back to accomodate for the TH400 which isnt a big deal but do I really need to use the Y looking ends or can I just bolt it straight to the frame??
Al
Old Oct 21, 2009 | 08:58 AM
1ATony's Avatar
Welcome to the site.
Old Oct 21, 2009 | 09:58 AM
Not sure about that one. You might want to take some pictures and post them. It is hard to visualize what you are talking about.
Old Oct 21, 2009 | 09:03 PM
70 cutlass s's Avatar
You might try making a plate to make it work. If its within a few inchs like 4 or 5 should work by cutting a plate that bolts to the trans. Than relocates the mount where bolts to the cross member normally. You can use a 1/8 inch metal plate cut it to size drill 4 holes in it use the mount for the right spacing between the holes. I would check in the engine forum I have read where a few guys on the sight have done the same swap. They might have better advise for you.
Old Oct 22, 2009 | 07:50 AM
citcapp's Avatar
If the mounting works out fine for the drive line angle the yes just bolt the crossmember to the frame. Use grade 8 bolts. You can build spacers for transmission mount at the transmission if you need to raise the angle
Old Oct 22, 2009 | 08:36 AM
Oldsguy's Avatar
Past Administrator
Looks like you already have some good suggestions, our members are quick on the draw here. Welcome to CO.
jag1886
Mar 18, 2011 01:16 PM
tnelson
Sep 9, 2010 05:57 AM
scubastever
May 6, 2010 08:51 PM
OldsMotion
Feb 1, 2010 10:24 PM
Big John 85
Feb 6, 2009 11:01 AM
