Carb adapter needed for 324 4 bbl!
Old Sep 1, 2009 | 05:34 PM
photomike's Avatar
Hey everybody! I'm trying to find a 4 bbl adapter to use a modern flange Holley on an old small square four barrel manifold.
I'd appreciate any help with this.
Thanks Much!
Mike
815-714-4309
Old Sep 2, 2009 | 05:10 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO. So you are saying the bolt locations are different, or the diameter of the four holes are smaller, or both? I think I have seen an adapter for that purpose but may be confusing the square bore to spread bore adapters which are common.
Old Sep 2, 2009 | 05:16 AM
wolfman98's Avatar
Captain of my ship
hang in there someone will know what you need. though a little more detail will help. hey Oldsguy beat me here too
Old Sep 2, 2009 | 05:52 AM
That is going to be tough. I am sure someone will know if there is a part that will work for your application.
Old Sep 3, 2009 | 04:15 AM
photomike's Avatar
324 manifold with Holley carb
My manifold is a stock 324 4 bbl manifold with small square four pattern. I want to put on a Holley 600.
Thanks!
Thanks Much!
Mike
815-714-4309
Old Sep 3, 2009 | 06:50 AM
Run to Rund's Avatar
I know what you mean. I thiink the bores in the manifold may be big enough for the small Holley, but Holley uses a more spread out mounting bolt pattern, still 5/16 x 18 thread I believe. you just need an adapter that goes from the tighter square pattern to the larger Holley pattern. I don't know if Mr. Gasket still makes them. Here is one link that might help; otherwise do a search for carb adapters.
http://www.summitracing.com/search/B...s/?Ns=Rank|Asc
ohiocutlassparts
Sep 13, 2017 09:29 PM
jensenracing77
Mar 16, 2014 06:13 PM
Uncle Hulka
Dec 28, 2011 08:17 PM
panamracer
Jul 27, 2009 05:24 AM
scott_442
Jan 21, 2009 05:19 AM
