Remove back seat
Old Jul 20, 2009 | 07:46 AM
Mason's Avatar
Remove back seat
I have a Olds 88 Touring car and need to get the back seat out. How do you do it? Really appreciate any advice.
Old Jul 20, 2009 | 09:55 AM
Oldsguy's Avatar
Past Administrator
What vintage? Welcome to CO.
Old Jul 20, 2009 | 10:48 AM
Mason's Avatar
1988 Olds Touring Sedan Four door
Hi, thanks for replying. It's a 1988 Olds Touring Sedan, 4 door.
Old Jul 20, 2009 | 11:04 AM
You probably pop the bottom of the seat out. It is usually held in place where part of the seat spring "clicks" in place around a hook welded onto the floor pan. Pushing the bottom of the seat back and up will usually get it to come loose. Then you loosen a few bolts and remove the back part of the seat by pushing it up. Not too difficult. Good luck.
Old Jul 20, 2009 | 11:41 AM
Mason's Avatar
Thanks.
Thanks very much for the information about getting the seat out. I need to get to the gas tank and somehow get the gas out before the car is towed away. Hate to see her go. Anyway, thanks again. I really appreciate the information.
Old Jul 20, 2009 | 11:54 AM
Oldsguy's Avatar
Past Administrator
Sorry, I was thinking you had a Delta88 and was wondering what year, Doh!
Old Jul 21, 2009 | 06:01 AM
IF you want to get the gas out of the tank then why do you need to remove the rear seat? If you are having it towed to the wrecking yard and need to remove the gas then just siphon the gas out of the tank into a plastic gas container for your lawn mower. Either that or run the car until the gas tank is empty (if the car runs).
Old Jul 21, 2009 | 06:42 AM
Mason's Avatar
gas in tank
I tried to syphon and it wouldn't work- I think there is a bend that hose won't go through - however, I'll try again - also car starts but that's it - tank is full - thanks for your help!
Old Jul 21, 2009 | 06:53 AM
Rdrokit's Avatar
If is going to the junk yard just take a large metal punch and hammer a punch a hole in the bottom of the tank and drain it into plastic containers. The car is going to get crushed at the yard. Hope that's not the case.
Old Jul 21, 2009 | 06:56 AM
Mason's Avatar
gas tank
Thanks - I guess I'll try the punch!
Mason
Christophe2m6
Dec 31, 2014 05:56 PM
nottyleradams
May 29, 2014 08:05 AM
1983oldsmobiledelta
Sep 23, 2010 06:50 PM
ctrain22
Aug 15, 2010 08:46 PM
KRICHEN922
Jul 1, 2010 09:17 AM
