New User, new car: All original 1969 Olds Cutlass Supreme.
Old March 12th, 2017, 01:50 PM
FapperTapper's Avatar
As the post title says, my name is Vince, I am a new user to this site and recently purchased my dream car. I found my Cutlass in a garage on a farm and it is all original minus some speakers put in.
I do need some help from this forum though and basically looking for input/direction on where to get the circuit board for the dash panel, a dash pad bolt diagram so I can pull that bad boy off, and the analog clock does not work, what could be the issue? Thanks for taking the time and hoping I can meet and swap with fellow enthusiasts.
FapperTapper is offline
Old March 12th, 2017, 02:24 PM
Member
timholliday's Avatar
Welcome to the site. Great looking car!
timholliday is offline
Old March 12th, 2017, 02:47 PM
Have you considered getting a Chassis Service Manual?
A Fisher Body Manual would be a good idea, as well.
Original copies of these are readily available on eBay.
The Assembly Manual can be helpful for little fiddling details, and is generally available only as a reproduction.
As for the clock, could just need to be cleaned up (usually, if you try to clean it up yourself, it'll work for about a week or so), or it may have a burned out winder coil - when the car is left sitting, the battery runs down, and at some point, does not have enough juice left for the coil to momentarily snap back the winder, so the coil just tries to pull, overheats, and burns a winding.
If you're careful, you may be able to find the break in the semi-microscopic wire and solder it up, but it ain't easy.
There are people who restore these, and it is also possible to install a modern quartz movement, though if you do, you will lose the characteristic second-hand movement, and the "clonk" of the winding mechanism every couple of minutes.
Welcome to ClassicOlds.
MDchanic is offline
Old March 12th, 2017, 03:34 PM
Welcome to the site, nice ride.
oldcutlass is online now
Old March 12th, 2017, 04:07 PM
Gary M's Avatar
Congrats on finding it
looks great for a barn find. When you do remove the dash pad be very careful and gentle when removing the nuts that hold it on and make sure they are all off before trying to pull the pad out. The studs break off Sometimes.
Gary M is offline
Old March 12th, 2017, 04:43 PM
Olds Fever
CRUZN 66's Avatar
Welcome to the group... Nice looking vehicle... If you should need a chassis service manual, I have one listed on the site for sale...
You can reference this thread: https://classicoldsmobile.com/forums...ce-manual.html
CRUZN 66 is offline
Old March 12th, 2017, 04:46 PM
Welcome, good looking Olds.
1969w3155 is offline
2blu442
April 14th, 2014 10:21 AM
kruss77
August 21st, 2009 07:35 AM
satanic-mechanic
February 13th, 2009 07:29 AM
BIGJERR
January 11th, 2009 05:46 PM
BIGJERR
November 26th, 2008 04:21 PM
Quick Reply: New User, new car: All original 1969 Olds Cutlass Supreme.
