Convertible Top Mounting
Old August 19th, 2011, 04:52 PM
dougm's Avatar
Can anyone tell me how the top cylinder piston mounts to the top frame. There is a bolt, nut, two folding washers and two bushings. The bushings go into the top cylinder piston and the bolt and nut holds it to the frame. Do the folding washers go between the bolt and frame or the frame and bushings?
Hopefully the pic is attached.
dougm is offline
Old August 19th, 2011, 04:57 PM
69442C's Avatar
The washers go between the bushings/side of rod end and the frame. The nut should be a locking nut (if not get locking nuts) and don't go crazy when you tighten it up. There will be a little play and that is fine so don't squeeze the frame tight to the washers/rod end.
69442C is offline
Old August 19th, 2011, 08:02 PM
dougm's Avatar
Thanks for the help
dougm is offline
Old August 21st, 2011, 06:37 AM
Past Administrator
Oldsguy's Avatar
Welcome to CO.
Oldsguy is offline
GoBigRed
Brakes/Hydraulic Systems
15
October 5th, 2015 01:00 PM
Goldhawg
October 7th, 2013 05:31 AM
dougm
August 15th, 2011 05:05 AM
shaks 442 clone
May 21st, 2007 04:38 PM
muddy
June 10th, 2006 04:24 AM
Quick Reply: Convertible Top Mounting
