nderise 70 w-30 restoration
Old November 23rd, 2014, 05:58 PM
NDERISE's Avatar
in the process of cleaning my under dash harness I realized I wash off all the lettering and #s of the fuse box. what to do. well this is what I did to fix it thought I would post some pics. of the outcome as this my help someone else.
remove the box from the harness I needed to anyway so I could clean terminals and seal them with die-lectric grease.
ordered a sheet of rub-on letters and #s
wiped the box down with grease and wax remover and started aligning and rubbing on the #s and a (for amps) then the I. d. lettering.
once I had all the lettering and #s on I cut a plastic straw in short pieces to cover the fuse terminals and applied 6 lite coats of high heat clear.
ray
NDERISE is offline
Old November 23rd, 2014, 06:24 PM
Paladin31's Avatar
Nice job Ray! Sounds like something I would do, lol, to wipe off the numerals, But helluva nice save. Looks great.
Brett
Paladin31 is offline
Old November 23rd, 2014, 06:50 PM
jensenracing77's Avatar
Great work! You want to do mine, lol. I have not started on my dash harness yet. Plan to start on that over the cold months.
jensenracing77 is offline
Old November 23rd, 2014, 07:08 PM
NDERISE's Avatar
Thumbs up fuse box restoration
eric just let me know if u need to redo it and I will do it for u, and maybe we can do some parts swapping for the service
thanks ray
NDERISE is offline
Old November 23rd, 2014, 07:11 PM
Octania's Avatar
wow
nice result
Octania is offline
Old November 23rd, 2014, 09:01 PM
steverw's Avatar
Very nice the letters look just like original to me. Very nice!
Steve
steverw is offline
Old November 24th, 2014, 05:13 AM
Eddie Hansen's Avatar
wow....
You made it sound easy, but that must have been some tedious work, those letters don't come individually and to get them all ligned up perfectly like you did took some patience, very nice.
Eddie Hansen is offline
Old November 24th, 2014, 05:17 AM
dc2x4drvr's Avatar
Nice job
dc2x4drvr is offline
Old November 24th, 2014, 06:10 AM
costpenn's Avatar
That is excellent work!! If you wanted to do it, I bet you could make a side business out of it.
costpenn is offline
Old November 24th, 2014, 10:20 AM
NDERISE's Avatar
thanks guys
thanks to all for the good comments, yes costpen u never know i'am getting close to retirement as I will be turning 64 in jan. and have allways loved to bring old things back to life, as I have restored cars, coke machines, candy machines and juke boxes, this may be a good pastime for a retiree, but I have many restoration projects ahead of me
thanks again to all nice comments ray
NDERISE is offline
Old November 24th, 2014, 10:27 AM
NDERISE's Avatar
takes time
yes it does take time and a good light source
thanks ray
NDERISE is offline
Old November 24th, 2014, 10:42 AM
Very nice, I used to use the same process for reviving instrument and control panels when the letters wore off. The clear will make it last a long time.
oldcutlass is online now
Old November 24th, 2014, 11:14 AM
NDERISE's Avatar
Yes they must be cleared to stay on and handle time and the elements of nature
ray
NDERISE is offline
Old November 25th, 2014, 03:33 PM
NDERISE's Avatar
good camera
I think I will start posting a few pics. of my progress on my car as now I have a phone that I can take decent pictures of my restoration on my car.
this are my inner fender which were in poor condition. I had to repair a few holes on the drivers side one and some spots that had a small crack, the small cracks I repaired by drilling 1/32 hold throw the cracked area and pushing stainless steel rods into the holds which prevents the crack from moving. also had to repair a couple of speed nut holes where they bolt up under the fender wheel opening. I used 3-m plastic bumper repair epoxy for the repairs. sanded the epoxy as u would bondo and primed with sems plastic primer. made my staples for the splash shields out of some stainless rod stock and located the staples in the original holes. worked on these inner fender for 4 weekends. I think they came out satisfactory considering the condition they were in. I considered using replacements but they are just not as good as the originals
ray
NDERISE is offline
Old November 25th, 2014, 03:42 PM
costpenn's Avatar
this are my inner fender which were in poor condition. I had to repair a few holes on the drivers side one and some spots that had a small crack, the small cracks I repaired by drilling 1/32 hold throw the cracked area and pushing stainless steel rods into the which prevents the crack from moving. also had to repair a couple of speed nut holes where they bolt up under the fender wheel opening. I used 3-m plastic bumper repair epoxy for the repairs. sanded the epoxy as u would bondo and primed with sems plastic primer. made my staples for the slash shields out of some stainless rod stock and located the staples in the original holes. worked on these inner fender for 4 weekends. I think they came out satisfactory considering the condition they were in. I considered using replacements but they are just not as good as the originals
ray
Those look great. I always enjoy seeing the before and after pictures.
costpenn is offline
Old November 25th, 2014, 04:21 PM
dc2x4drvr's Avatar
Wow, very nice repair..
Old November 26th, 2014, 05:29 AM
Excellent job, and nice save
Old November 26th, 2014, 02:08 PM
72 Olds CS
RetroRanger's Avatar
The inner fenders came out really nice. Did you use the SEM paint to paint them as well? If yes what color.
RetroRanger is offline
Old November 26th, 2014, 02:37 PM
ray
Please do! You are doing great work!
Old November 26th, 2014, 03:28 PM
NDERISE's Avatar
15313
yes retro sems #15313 flame red
ray
NDERISE is offline
Old November 27th, 2014, 11:30 AM
NDERISE's Avatar
steering knuckle
just thought I would post some pictures of the inspection marks I found on my steering knuckles. does anyone have any info. on all the diff. colors, 4 diff. ones from what I can see orange, yellow, green and blue
ray
NDERISE is offline
Old November 27th, 2014, 08:20 PM
Lance
ROCKET VAPOR's Avatar
My Fremont built '70 has the same very dark green markings with the baby blue swoosh mark.
Yellow marks are generally associated with torqueing being complete or verified.
ROCKET VAPOR is offline
Old December 1st, 2014, 05:05 PM
NDERISE's Avatar
rocket vapor did u redo the knuckle in the pic and if so what type of blue paint did u use
thanks ray
NDERISE is offline
Old December 2nd, 2014, 12:10 PM
Lance
thanks ray
I got a collection of Testors model car paint from Hobby Lobby and mixed colors until a match was achieved.
FWIW, I try to keep in mind with some of these 44 year old color markings that there may be at the least some slight fading of colors over time.
Old December 2nd, 2014, 12:28 PM
NDERISE's Avatar
that is a great idea I never thought of using model paint
thanks ray
NDERISE is offline
Old December 3rd, 2014, 05:15 PM
NDERISE's Avatar
diff. resto.
this is a few pics. of my diff. restoration. after stripping it down to the housing I washed it down with superclean. dried it out and blasted it. primed in with etch primer and flashed primed it with epoxy primer. the driver side had some bad pitting after two rounds on priming and sanding I tried putting 3 heavy coats of primer and while It was not quite dry I used a 4" razor blade to cut the primer on the diff. tubes. I also cut the primer on the flat areas of the shock and control arm brackets. doing this save me a lot of time priming and sanding. finally got all the pit out and chassie blacked it came out pit free and slick.
thanks for viewing ray
NDERISE is offline
Old December 3rd, 2014, 06:13 PM
Dang that housing came out great....
Old December 3rd, 2014, 06:30 PM
costpenn's Avatar
Your car is going to be simply awesome. I tried filling a lot of the pits on my tubes, and it did not come out anywhere nice as yours!! Nice shop - what is that railroad sign from? Trains is another of my hobbies.
costpenn is offline
Old December 3rd, 2014, 06:37 PM
NDERISE's Avatar
it is a very heavy old railroad crossing street sign I pick up in miss. when I was at cruising the coast. one section was broken and I ended up selling it to another guy. but I do have about 300 other signs in my collection. these are a few pics. of things in my office.
thanks ray
NDERISE is offline
Old December 3rd, 2014, 07:16 PM
Cincinnati Rick's Avatar
Can you explain what you meant by cutting the primer on the differential tubes?
Cincinnati Rick is offline
Old December 4th, 2014, 05:21 AM
  #31
NDERISE's Avatar
AFTER SPARYING 3 HEAVY COATS OF PRIMER IT TAKES LONGER TO DRY AFTER A FEW MINETS (ITS HARD TO KNOW EXSACCULY WHEN BECAUSE OF CONDITIONS) I USED A 4" AND A REGULAR 1" RAZOR BLADE TO CUT ALONG THE SUFACE OF THE TUBE, CUTTING WITH THE CURVE OF THE TUBE (NOT THE LEIGHT) LIKE IF U WOULD BE SCRAPING PAINT OFF A PEACE OF GLASS AS U CUT THROUGH THE PRIMER THE REMAINING PRIMER STAYS IN THE VOIDS (PITS). AFTER CUTTING THE PRIMER U NEED TO LET IT DRY ABOUT 2 DAYS BEFORE SANDING IT.
REMAINING PRIMER STAYS IN THE VOIDS (pits). A REPRIMING AND FINISH SANDING WILL BE NEEDED
HOPE THIS HELPS U UNDERSTAND
RAY
NDERISE is offline
Old December 4th, 2014, 09:53 AM
  #32
RAY
Makes sense. Thanks for the explanation. I love learning new tricks. I hope some of my work turns out as nice as yours.
Old December 5th, 2014, 04:07 PM
  #33
NDERISE's Avatar
console
spent most of the day cleaning my replacement console which is black as it will need to be repainted as I will repaint most of my interior parts. removed the lock assembly the plastic rivets that retain the door opening molding and compartment cover, removed the larger lower chrome molding. polished the moldings, cleaned all plastic parts with super clean.
then started on reflocking the console compartment. masked off the necessary areas. sprayed two coats of black enamel paint for the flocking to stick to. very happy with the results, all came out looking as good as a factory application.
don't laugh at my flocking application pump its home made and work great.
THANKS RAY
NDERISE is offline
Old December 5th, 2014, 04:12 PM
  #34
mrolds69's Avatar
Looks excellent...nice work!
mrolds69 is offline
Old December 5th, 2014, 07:50 PM
  #35
costpenn's Avatar
Ray, here's a few more obscure original markings and labels I found on my car during the tear down. I'll post some more later- let me know if you need any further info on these pics.
costpenn is offline
Old December 5th, 2014, 08:11 PM
  #36
NDERISE's Avatar
colume tag
I had a tag on my steering column but it was in poor condition and could not read it, I would like to find one in good condition to see if I could reproduce one for my column. maybe your was readable. if so maybe u could p m me a good pic of it. thanks for the pics. of the inspection marks u sent. I would like to put all the insp. mark possible. I still have my fuel tank that is in good shape and will take a close look at it for marks
thanks ray
NDERISE is offline
Old December 5th, 2014, 08:32 PM
  #37
costpenn's Avatar
thanks ray
Here you are. It is the original in the original position
costpenn is offline
Old December 6th, 2014, 03:27 AM
  #38
rob1960's Avatar
Nice work so far!!! I love watching these cars being brought back! Outstanding redo on the red fender liners!!!
rob1960 is offline
Old December 7th, 2014, 05:54 PM
  #39
NDERISE's Avatar
glove box
found inspection marks on my inner glove door liner today as I was sanding out some scratches and buffing it out. picture one below looks like just a white line and picture two looks like a 3 made with a yellow pencil. costpenn thanks for the picture of the colume tag and if the tag is handy would it be possible to mic it so I will have the measurements to try to reproduce me one.
thanks ray
NDERISE is offline
Old December 10th, 2014, 07:15 PM
  #40
NDERISE's Avatar
rear seat bottom
here are a few pics of my rear seat bottom I took pics as I assembled them blasted the frame etch primed them and painted them in satin nickel as to give them a natural metal finish as the frames were not painted from the factory, replaced all burlap, cotton and foam, sewed thin metal wire supports to new burlap, installed legendary cover.
NDERISE is offline
Quick Reply: nderise 70 w-30 restoration
