Oldsmike's Draggin' Wagon Build
Yes, Yes, Yes, I know I can go a lot faster with a lighter Olds and my detractors on this car are many. Although there are also many that can't get enough of it! I just had a guy in my shop and he looked at me crosseyed and said "Why would you spend money on that when you could be putting money in that Cutlass over there?". I didn't answer the question because, well, I don't need to. The best part is anywhere I go with this car, odds are, I know it will be the only one like it. That, short and simple, is the reason I enjoy it so much. It is unique.
Finally got a bunch of parts in for my Custom Cruiser!
Work done this week!
Engine came out last weekend... Lots of cleanup and I really need to junk the HVAC box, takes up WAY too much room. I'd like to pick up a standard heat box (non-A/C) but not sure these were ever made that way.
http://www.flickr.com/photos/22958812@N08/5788793556/http://www.flickr.com/photos/22958812@N08/5788793556/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Here is the old 455. Heads and intake being swapped over to the new Olds 461.
http://www.flickr.com/photos/22958812@N08/5788237535/http://www.flickr.com/photos/22958812@N08/5788237535/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Ram Air system is in and I'm starting to do my fit ups. This is going to look really good when finished!
Before:
http://www.flickr.com/photos/22958812@N08/5788238323/http://www.flickr.com/photos/22958812@N08/5788238323/ by http://www.flickr.com/people/22958812@N08/, on Flickr
After:
http://www.flickr.com/photos/22958812@N08/5791510917/http://www.flickr.com/photos/22958812@N08/5791510917/ by http://www.flickr.com/people/22958812@N08/, on Flickr
The dual air inlets will be connected to dual 4" pipes and terminating into a dual inlet air intake box. I will be easily finished with this portion this week.
More to come this weekend.
Before:
After:
Cool wagon!
What trans/rear are you using? What kind of engine mods. have you done. I'm wanting to get a set of aluminum heads for my Vista. I'm at about 9.6 comp. right now & I've heard you can go up to about 11? What has your experience been?
Pretty sure I've seen this car at Homecoming a few times.
I love the wagons, and a "G" body Cutlass is so common. If I didn't have a Delta 88 I would have the Custom Cruiser.
The Wagon weighs in at 4200 lbs (i think it's 4214 is be exact) and the Delta 88 tips the scales at 3982, and guess how much a "G" body Cutlass weighs, in the 3600 lb neigbhood. Very easy to shave off the 300 lbs and still have a street legal, clean, uncommon, drag car and if you don't shave off the weight what is 300 lbs, .3 in the 1/4 mile. Ooooooo, so you're not running 12's your running 12.3.
I agree that people looked at me weirdly becasue I was racing a Delta 88, but guess what, just like you I want to be different and stand out from the crowd.
More power to you!!
More power to you!!
The new 461 has Ross Pistons, Eagle Rods, Comp Cams Roller Cam & Lifters. CR should be a true 10.5:1. Cam Lift is 0.600/.585 (I/E) on 108 degrees. Edelbrock Performer RPM heads and Torker intake topped with a Holley 950 HP carb. This is a significant upgrade to what I just took out.
Aluminum heads reduce detonation due to heat loss. What the real number is compared to Iron heads is unknown to me. My guess is about half a point in what I've read but I can't prove it... If you are running a true 11:1 CR, I'd suspect you will detonate on pump gas regardless of how you timed the engine. I plan on running a mix of race gas and premium.
Hope I've answered your questions...
Thanks for the kudos!
More power to you!!
More power to you!!
You are right on the weight. I found a aluminum hood which is being painted right now. That will save sixty plus pounds off the front. I'm also ditching the steel Cragar Quick Tricks to Weld Racing Pro Stars. Some significant weight savings there!
Regards,
Mike
Where did you find such a hood Fellow "B" body guys want to know
I'm running nearly 11:1 comp.(Calculated 10.997:1 and I don't detonate on premium unleaded using Edelbrock heads. My engine guy claims all things equal you can run about 1 full point more compression using aluminum heads because they pull heat from the chamber a lot more efficiently. Nice ride, btw.I think the best part about your car is how the ricer chaches must underestimate how fast your car is.:-)
I have some pics but want to save them till I get a few more. Axles are out of the rear. I have a guy in Flint who has a set of Moser axles that I'm looking to pick up. May upgrade to a spool and sell the Eaton Posi that I have. Got my aluminum hood hinges, one is here the other will be shipped shortly. Boy, are they light!
The "Super Bar" came in tonight, it's a beast! Front end should come up nice and square. I'm still waiting for my Metco upper and lower control arms to come in.
For this year, I think I may just put an aluminum plate over the HVAC box hole on the firewall and then after race season is over find a regular non AC box to put in there.
I have a full boogie TH400 with a trans brake ready to go, thinking I might put that in and do a refresh on the existing TH400 that was in it.
That's it for now,
Pics coming this week or weekend...
Mike
That's it for now,
Mike
What headers fit this body? I think 74 Cutlass shorty headers fit, but I saw a 77 Delta with a 455 and headers at homecoming. The owner wasn't around so I couldn't ask him what headers they were. They looked like long tube and didn't look like they were "made" to fit
Lots more done again, will have some more pics Sunday night.
What car are they for? I know they don't have a listing for the 77-90 B Body
New axles mean that the Eaton Posi needs updated. Spider gears updated to 30 spline.
http://www.flickr.com/photos/22958812@N08/5874419727/http://www.flickr.com/photos/22958812@N08/5874419727/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Did I say new axles? Moser's that I have had redrilled to 5 x 4.75 so that I had options for aluminum rims.
http://www.flickr.com/photos/22958812@N08/5874979288/http://www.flickr.com/photos/22958812@N08/5874979288/ by http://www.flickr.com/people/22958812@N08/, on Flickr
http://www.flickr.com/photos/22958812@N08/5874418263/http://www.flickr.com/photos/22958812@N08/5874418263/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Drums were also redrilled.
http://www.flickr.com/photos/22958812@N08/5874978596/http://www.flickr.com/photos/22958812@N08/5874978596/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Carrier removed.
http://www.flickr.com/photos/22958812@N08/5874419995/http://www.flickr.com/photos/22958812@N08/5874419995/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Carrier put back in.
http://www.flickr.com/photos/22958812@N08/5874977450/http://www.flickr.com/photos/22958812@N08/5874977450/ by http://www.flickr.com/people/22958812@N08/, on Flickr
The cleaned up Torker with the Holley on it.
http://www.flickr.com/photos/22958812@N08/5874417871/http://www.flickr.com/photos/22958812@N08/5874417871/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Lots more to do judging by the parts...
http://www.flickr.com/photos/22958812@N08/5874978958/http://www.flickr.com/photos/22958812@N08/5874978958/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Carrier removed.
Sorry, I'm remiss in posting pics. I've been working on the wagon instead. I am taking pics just haven't posted yet.
The aluminum hood is painted and ready for fit up, looks great. The aluminum hinges are all clean with hinges lubricated.
The Metco lower control arms are installed, putting on the 1.5" sway bar tomorrow night. Getting the axle tubes welded to the carrier and installing C-clip eliminators will have to wait till this winter as I'm out of time. I'll put in the Metco adjustable upper control arms at that time as well. The Weld Racing Rims were mounted to the BFG Drag Radials and fit like a charm!
HVAC has been gutted and I'm putting a aluminum cover over the hole. I'll look for a non-AC HVAC unit to put in there later.
The Olds 461 Roller has cleaned up Edelbrock heads and Torker intake installed as well as the water pump/neck and T-stat. The MSD had some corrosion in it and will be cleaning that tomorrow night as well.
Still need to put the Battery in the spare tire well and route the wires. Also need to finish the conversion of the front rotors to 5 x 4.75. I need to cut on the core support some more to finish clearance for the Ram Air system, easy work, won't take long. Probably Thursday or Friday for that. Motor is planned on going in on Saturday. It looks great!
The good news is the pile of parts has dwindled substantially and not much left to install. Have to repair the RH door seal and the windshield washer pump... plenty of time for that.
Not to hi jack the thread but I'll let you know If I find another. Unless you want to make the trip up and I'll show you the yards I hit. BTW the aluminum hood and hinges saves exactly 47lbs on a B-body. You have to have both. BTW this is a great wagon build.
In time What year did they start with the aluminum hood?
Redog,
Here is your pic for the crossmember. Stickman has some pics of his in his thread, similar to what I did but a little different...
http://www.flickr.com/photos/22958812@N08/5920357190/http://www.flickr.com/photos/22958812@N08/5920357190/ by http://www.flickr.com/people/22958812@N08/, on Flickr
http://www.flickr.com/photos/22958812@N08/5919788539/http://www.flickr.com/photos/22958812@N08/5919788539/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Finally some pics! Enjoy!
The axles are set here, ready for the C-Clips, you can see those on the ground.
http://www.flickr.com/photos/22958812@N08/5919791023/http://www.flickr.com/photos/22958812@N08/5919791023/ by http://www.flickr.com/people/22958812@N08/, on Flickr
On the ground. Nice and light, look great!
http://www.flickr.com/photos/22958812@N08/5920351418/http://www.flickr.com/photos/22958812@N08/5920351418/ by http://www.flickr.com/people/22958812@N08/, on Flickr
The flash really highlighted the Blue on the drums, they don't show up that bright at all.
http://www.flickr.com/photos/22958812@N08/5920353436/http://www.flickr.com/photos/22958812@N08/5920353436/ by http://www.flickr.com/people/22958812@N08/, on Flickr
The MSD ignition had a LOT of corrosion in it.
http://www.flickr.com/photos/22958812@N08/5920352536/http://www.flickr.com/photos/22958812@N08/5920352536/ by http://www.flickr.com/people/22958812@N08/, on Flickr
The weights had corrosion too.
http://www.flickr.com/photos/22958812@N08/5920351642/http://www.flickr.com/photos/22958812@N08/5920351642/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Tore down the distributor so I could clean everything. I also had to swap in the new gear made specifically for a Roller Cam. The gear can be put on backwards so you have to pay a little attention.
http://www.flickr.com/photos/22958812@N08/5919790471/http://www.flickr.com/photos/22958812@N08/5919790471/ by http://www.flickr.com/people/22958812@N08/, on Flickr
MSD all put together... and clean!
http://www.flickr.com/photos/22958812@N08/5919791857/http://www.flickr.com/photos/22958812@N08/5919791857/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Couple shots of the engine in the rollable cradle I built.
http://www.flickr.com/photos/22958812@N08/5920353924/http://www.flickr.com/photos/22958812@N08/5920353924/ by http://www.flickr.com/people/22958812@N08/, on Flickr
This one shows the solid motor mount on the drivers side of the engine.
http://www.flickr.com/photos/22958812@N08/5920355740/http://www.flickr.com/photos/22958812@N08/5920355740/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Right before the Intake was put on.
http://www.flickr.com/photos/22958812@N08/5919795137/http://www.flickr.com/photos/22958812@N08/5919795137/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Another view in the cradle.
http://www.flickr.com/photos/22958812@N08/5920357856/http://www.flickr.com/photos/22958812@N08/5920357856/ by http://www.flickr.com/people/22958812@N08/, on Flickr
The aluminum hood is back!
http://www.flickr.com/photos/22958812@N08/5920352872/http://www.flickr.com/photos/22958812@N08/5920352872/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Engine going in!
http://www.flickr.com/photos/22958812@N08/5919792921/http://www.flickr.com/photos/22958812@N08/5919792921/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Engine in and starting to put things together.
http://www.flickr.com/photos/22958812@N08/5920356246/http://www.flickr.com/photos/22958812@N08/5920356246/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Headers are on, exhaust hooked up.
http://www.flickr.com/photos/22958812@N08/5920356722/http://www.flickr.com/photos/22958812@N08/5920356722/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Some rear suspension pics:
http://www.flickr.com/photos/22958812@N08/5920354250/http://www.flickr.com/photos/22958812@N08/5920354250/ by http://www.flickr.com/people/22958812@N08/, on Flickr
http://www.flickr.com/photos/22958812@N08/5920352028/http://www.flickr.com/photos/22958812@N08/5920352028/ by http://www.flickr.com/people/22958812@N08/, on Flickr
http://www.flickr.com/photos/22958812@N08/5920356920/http://www.flickr.com/photos/22958812@N08/5920356920/ by http://www.flickr.com/people/22958812@N08/, on Flickr
The hood striker was broken, so this plate was fabbed. Added some strength to the hood in this area and looks good.
http://www.flickr.com/photos/22958812@N08/5919792349/http://www.flickr.com/photos/22958812@N08/5919792349/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Engine going in!
#32
Took the wagon Racing at Norwalk last weekend. Ran a best of 12.33 at 106.56.
http://www.flickr.com/photos/22958812@N08/5956226832/http://www.flickr.com/photos/22958812@N08/5956226832/ by http://www.flickr.com/people/22958812@N08/, on Flickr
http://www.flickr.com/photos/22958812@N08/5955665029/http://www.flickr.com/photos/22958812@N08/5955665029/ by http://www.flickr.com/people/22958812@N08/, on Flickr
http://www.flickr.com/photos/22958812@N08/5955663937/http://www.flickr.com/photos/22958812@N08/5955663937/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Nice pic taking her off the trailer...
http://www.flickr.com/photos/22958812@N08/5955656481/http://www.flickr.com/photos/22958812@N08/5955656481/ by http://www.flickr.com/people/22958812@N08/, on Flickr
Leaving to break in the new engine, oops, my foot slipped....
http://www.flickr.com/photos/22958812@N08/5955656729/http://www.flickr.com/photos/22958812@N08/5955656729/ by http://www.flickr.com/people/22958812@N08/, on Flickr
#34
No problems at all with the height. There is one pipe too close to the firewall on the LH side. It's a flange and can be bent down (the flange) for clearance if needed.
The Stickman
Vista Cruiser & Wagons
17
March 26th, 2010 06:49 AM
