Windshield wiper control
Old October 27th, 2014, 12:28 PM
dc2x4drvr's Avatar
Does anyone recall the size and quantity of the retaining nuts? This is for a '71 442.
dc2x4drvr is offline
Old October 27th, 2014, 08:45 PM
70Post's Avatar
Lance - Are you referring to the chrome faceplate/bezel OR the wiper switch itself.
Faceplate is held on with two VERY SMALL stamped speed nuts....who knows what size those are...probably need a microscope to figure that out!
Switch is held on with 3 #8 x 1/2" hex flange screws (1/4" socket size for the head)
If you need some let me know.
70Post is offline
Old October 28th, 2014, 05:37 AM
dc2x4drvr's Avatar
I need to remove the bezel so I can replace the wood grain. I'm thinking the nuts are 5/16", and I wanted to be tooled up with correct socket.
Old October 28th, 2014, 10:30 AM
70Post's Avatar
The stamped speed nuts are also 1/4" socket size....if the bezel mounting studs are stripped a bit then just pry/pull against the bezel from the frontside while turning the socket on the nuts.
70Post is offline
Old October 28th, 2014, 10:59 AM
dc2x4drvr's Avatar
Thanks Patton, getting those nuts off is a Ray Charles operation
Old October 28th, 2014, 11:19 AM
70Post's Avatar
That and Harry Houdini as you'll get to do some contortionist maneuvers at the same time. Getting back up after all that is the real challenge!
70Post is offline
defiant1
May 28th, 2010 06:08 AM
jpaulwhite
April 26th, 2010 04:25 AM
2blu442
January 3rd, 2010 05:28 PM
Oldskeeper
September 15th, 2008 06:59 PM
BaileyJD1
May 10th, 2008 03:33 AM
Quick Reply: Windshield wiper control
